Power Up Ethernet Shield W5200 OK until Power Down Up
Sketch works OK until disconnect/reconnect USB (power) to Arduino UNO.
SETUP: Windows 7, Arduino Uno, W5200 Ethernet Shield, Relay Shield
What do I have to do to make this sketch work stand alone without having to reload sketch after each power up?
#include <SPI.h>
#include <EthernetV2_0.h>
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
IPAddress ip(192,168,200, 2);
IPAddress gateway(192,168,200, 1);
IPAddress subnet(255, 255, 255, 0);
// telnet defaults to port 23
EthernetServer server(23);
#define W5200_CS 10
#define SDCARD_CS 4
// int Relay1 = 4; Relay1 (pin 4) conflicts with W5200 Ethernet Shield)
int Relay2 = 5;
int Relay3 = 6;
int Relay4 = 7;
String commandString;
delay(2000);
pinMode(Relay2, OUTPUT);
pinMode(Relay3, OUTPUT);
pinMode(Relay4, OUTPUT);
pinMode(SDCARD_CS,OUTPUT);
digitalWrite(SDCARD_CS,HIGH);//Deselect the SD card
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
// wait for a new client:
while (client.available()){
char newChar = client.read();
if (newChar == 0x0D)
processCommand(commandString);
// gotAMessage = false;
client.stop();
} else
commandString += newChar;
void processCommand(String command)
if (command.indexOf("RelayOn") > -1){
digitalWrite(Relay2,HIGH);
digitalWrite(Relay3,HIGH);
digitalWrite(Relay4,HIGH);
commandString = "";
return;
if (command.indexOf("RelayOff") > -1){
digitalWrite(Relay2,LOW);
digitalWrite(Relay3,LOW);
digitalWrite(Relay4,LOW);
commandString = "";
return;
commandString = "";
Which w5200 shield are you using? The DFRobot shield has a couple strange setup requirements.
Does it start to work if you press the reset button on the shield/Arduino?
This is incorrect, but may not be the cause of your problem.
// change this
// to this
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
// or this
  Ethernet.begin(mac, ip);
Thank you for your reply.
I am using W5200 Ethernet Shield v2.2 02/20/2014 06A14 by Seeed Studio purchased at Radio Shack
YES, If I press the reset button on the Ethernet Shield it will start working.
What do I need to do to eliminate the pressing of the "reset" button on power up?
Why do you say "This is incorrect, but may not be the cause of your problem."
Is the documentation in error?
// initialize the ethernet device
// start listening for clients
server.begin();
My code: Ethernet.begin(mac, ip, gateway, subnet);
You suggest: Ethernet.begin(mac, ip, gateway, gateway, subnet);
I don't know what to tell you about the boot problem. I have Due that suffers from the same malady.
The begin function has several prototypes. If you pass only 4 parameters, the last parameter is the gateway. You are using the subnet mask 255.255.255.0 as the gateway.
  void begin(uint8_t *mac_address, IPAddress local_ip);
  void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server);
  void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server, IPAddress gateway);
  void begin(uint8_t *mac_address, IPAddress local_ip, IPAddress dns_server, IPAddress gateway, IPAddress subnet);
