When I turn on the unit, the logic controller ( ItsyBitsy 32u4 - 3V ) does not boot up.
It boots up just fine when I connect the USB, then runs properly even when the USB is disconnected!!!
Yes, I checked the power. It is right on at 3.2V.
Here is a screenshot of the schematic.
What is MAX1684? I am not using that device.
jim-p yes I am using while(!Serial). Commenting them out solved the problem. Thanks for the clue
Is there a way to check if the USB is connected or not?
Commenting out the while(!Serial) code fixed the problem. When it is boots up it hangs up because there is no USB connection. Which causes the while to enter a endless loop,
Yes, that's effectively what 'while(!Serial)' does. But it takes a second or two to connect after plugging in, hence the while loop to wait for that to happen.
You can set a timeout:
unsigned long startTime = millis();
while (!Serial and millis() - startTime < 3000);
