FuzzyYYYY:
I have a question that's been plaguing my mind. IF my my lap top runs on 3.5-5V DC possibly 12V DC why do I feed it 120V AC and on a Mac... how would one come to some saner solution than 120AC of EXPENSIVE solar system built to produce 120V to be dropped down to quite often 5-3.5V... I'm just not seeing the logic of 120V in at source power...
Legacy - world electrical grid systems settled on 120/240 VAC a long time ago - so that's what we're stuck with.
Most solar panel installs are typically 24 volt or 48 volt from the panels to the battery bank/inverter system - which then converts things to "mains level" for the house or whatnot.
Lastly - and this is the "big one": Barring super-conductive wiring (note that room-temperature super-conductive wiring does not exist, at least outside of the lab) - the greater the voltage you can push down a wire, the smaller that wire (it's "gauge" - generally measured as the thickness or diameter of the wire - note that this will vary depending on if it is stranded vs solid core wire) that can be run for a given distance and voltage drop.
Even the best wire available has some measure of resistance for a given length of it - it may be low, but it isn't zero (otherwise, it would be a "super-conductor"!). In general, the thinner the wire, the greater resistance it has. Since according to Ohm's Law, current = voltage / resistance, the more you increase the voltage, the more current the wire can effectively carry. If you wanted to use a lower voltage, you need to lower the resistance to carry the same amount of current - meaning you need thicker wire, or wire that was more conductive (less resistance). Either way - it's going to get expensive.
Use copper or aluminium wire - but make it thicker --> $$$
Use silver or graphene wire - at normal thickness, but because it is more conductive --> $$$
Instead - up the voltage, use copper or aluminium for better conductivity (in the middle is gold - no good) - and have thinner wire over a distance (even the length of a house is enough to make lower voltages and thicker wire an issue).
Note something like the cables that run from your car battery to the starter; they are copper, but are meant to carry many hundreds of amps when starting. Since the car battery is (typically) 12 volts, the wire needs to be very thick (1-2 gauge, or thicker) to carry the current without overheating (because since wire has resistance, it will drop voltage and dissipate some of that as heat). Such wire is extremely expensive (a similar scenario is in the arc-welding world, where voltages can drop down to only a few volts, with extremely high currents - extension cables for the electrodes - even short ones - can run into the $100s USD due to the thickness needed).
What we are likely to see in the future for solar will actually be larger DC voltages (not smaller) - so to make the wiring cheaper. I could see a 96 volt system in the near future. It may also likely make the inverters less expensive. I can see the same with automobiles - a 48 volt LiPoly (or something similar) battery with thinner cables to the starter. Both of these will likely come about as copper becomes more expensive.
There may also be a switch back to aluminum wire - though I fear that we'll see similar things happen in houses as they did in the 1970s - lots of houses built during that time have either caught fire, or catch fire today in a regular manner - because of the number of aluminium to copper or brass interconnects, which have an extremely high resistance issue that doesn't tend to trip breakers. I live in a neighborhood filled with houses constructed in the 1970s - and every year, one or two houses will catch fire (usually because someone had plugged in something with a greater current than what the plug could handle - and the breaker does trip - but the dissimilar metal issue makes the problem larger). The house I own and live in already had a fire prior to when my wife and I bought it. Fortunately, the original owner refitted the entire house out with copper wire afterwards.
