Powerbank with solar pannel
Hello, I want to build a powerbank with solar pannels. Momentanly I have 2 solar pannels 5VDC 400mA, 18650 batteries and LED Dual USB 5V 2.4A Micro/Type-C USB Mobile Power Bank 18650 Charging Module Lithium Battery Charger Board Circuit Protection. ( https://shorturl.at/aoTV8)
Now I would need a scheme or help to be able to achieve this project. From what I understand the solar panels need to be connected to a zenner diode but I don't know exactly which one all I have at the moment is a 4.7v diode which I don't know if it's ok to put in the circuit.
So if you could help me with a scheme or any help is welcome.
Post an annotated schematic of your planned system. Be sure to show all parts, connections, power sources and loads.
Adafruit carries well designed solar charge modules. I recommend that you consider using them, or at least carefully study the design principles. All the details of the designs are published.
Depends of what you really have. Just plain panels or panels with usb connector?
Most panels 5V/400ma are with usb and have circuit already inside. So don't start playing with diodes, it this is the case.
Show what you have.
