Hello ive been working on some code to for a simple powerfeed and got most of it working only things i now run in to is that when no switch is made the enable should be made high ie 5v at the moment it goes low to ground easily fixed in the wiring but is it also possible in the code ?
Second when a switch is selected and my 10k pot is all the way to 0 it still turns and i want it to then be still/stopped is there a way to fix that?
or would it be better to use ContinuousStepper lib?
#include <AccelStepper.h>
#include <timeObj.h>
#include <mechButton.h>
#include <mapper.h>
#include <autoPOT.h>
#define DIR_PIN 2
#define STEP_PIN 3
#define CW_PIN 10
#define CCW_PIN 11
#define RAPID_PIN 12
#define SPEED_PIN A0
#define ENABLE_PIN 4
#define PRINT_MS 1000
#define MAX_SPEED 1000
AccelStepper stepper(AccelStepper::DRIVER, STEP_PIN, DIR_PIN);
timeObj printTimer(PRINT_MS);
mechButton CWBtn(CW_PIN);
mechButton CCWBtn(CCW_PIN);
mechButton RapidBtn(RAPID_PIN);
autoPOT speedPOT(SPEED_PIN);
mapper speedMap(0,1023,0,MAX_SPEED);
enum states { waiting, moveCW, rapidCW, moveCCW, rapidCCW };
states ourState;
float moveSpeed;
CWBtn.setCallback(CWClick);
CCWBtn.setCallback(CCWClick);
RapidBtn.setCallback(RapidClk);
speedPOT.setCallback(newSpeed);
Serial.println("The sketch has started");
stepper.setMaxSpeed(MAX_SPEED);
stepper.setSpeed(0);
ourState = waiting;
void CWClick(void) {
switch(ourState) {
case waiting :
if (!CWBtn.getState()) { // Switch grounded..
if (CCWBtn.getState()) { // CCW is NOT grounded..
comMoveCW();
} else if (!CCWBtn.getState()) { // CCW is grounded..
comMoveCCW(); // We go the other way!
case moveCW : // Any of these, means stop.
case rapidCW :
case moveCCW :
case rapidCCW : comStop(); break;
void CCWClick(void) {
switch(ourState) {
case waiting :
if (!CCWBtn.getState()) { // Switch grounded..
if (CWBtn.getState()) { // CW is NOT grounded..
comMoveCCW();
} else if (!CWBtn.getState()) { // CW is grounded..
comMoveCW(); // We go the other way!
case rapidCW :
case moveCCW :
void RapidClk(void) {
switch(ourState) {
case waiting : break;
case moveCW :
if (!RapidBtn.getState()) { // Switch grounded.
comRapidCW(); // Run up to rapid speed.
case rapidCW :
if (RapidBtn.getState()) { // Switch released.
comMoveCW(); // Slow down to move speed.
case moveCCW :
comRapidCCW(); // Run up to rapid speed.
case rapidCCW :
comMoveCCW(); // Slow down to move speed.
void newSpeed(int newValue) {
moveSpeed = speedMap.map(newValue);
switch(ourState) {
case moveCW : stepper.setSpeed(moveSpeed); break;
case moveCCW : stepper.setSpeed(-moveSpeed); break;
case rapidCW : // These two do nothing.
case rapidCCW : break;
void comMoveCW(void) {
digitalWrite(ENABLE_PIN, LOW);
ourState = moveCW;
void comMoveCCW(void) {
ourState = moveCCW;
void comRapidCW(void) {
stepper.setSpeed(MAX_SPEED);
ourState = rapidCW;
void comRapidCCW(void) {
stepper.setSpeed(-MAX_SPEED);
ourState = rapidCCW;
void comStop(void) {
digitalWrite(ENABLE_PIN, HIGH);
ourState = waiting;
idle();
stepper.runSpeed();
if (printTimer.ding()) {
switch(ourState) {
case waiting : Serial.print("waiting "); break;
case moveCW : Serial.print("Move CW "); break;
case moveCCW : Serial.print("Move CCW "); break;
case rapidCW : Serial.print("Rapid CW "); break;
case rapidCCW : Serial.print("Rapid CCW "); break;
Serial.print("Speed : ");
Serial.print(stepper.speed());
Serial.print(" Pos : ");
Serial.println(stepper.currentPosition());
printTimer.start();
