Powerfull outputs ?
Would it be any simple solution to have each output delivering a Voltage similar to the voltage input ?
In fact I need to control a chain of leds of 5 outputs pins of 160ma with up to 15V. Is there any cool way ?
I imagine one solution with some transistor controlled by each ouput but perhaps there is a more elegant solution....
Thanks for idea.
Sebastien
There is no simpler solution than to use an external transistor or FET. The FET is the simplest because there is no need to add a resistor like you have to in the base of a transistor.
