Powering 1/2hp dc motor
I have a 1/2 hp 12vdc motor on a piece of equipment. I don't have the motor specs in front of me, but a web search suggests it is a 1700 rpm motor that uses between 10 and 60 amps.
Currently it has speed control in one direction, but a set speed in the other. I want to be able to replicate this ability and power the direction and speed from my Arduino if possible. I might even want to control speed in both directions. I may also look into updating to a 3/4hp motor at some point (10 to 75A), so I'd like to get a controller I could still use with that.
I'm pretty new to electronics, but I'm guessing I need some kind of H-bridge for this? All the ones I find seem to be for smaller motors. Is there something out there that someone can point me to? I'd be willing to build an H-bridge if I can get a good grasp on what components I need. Thanks.
You need a full H-bridge.
You could build a H-bridge with power mosfets.
But also a number of mosfet H-bridge modules can handle that current.
You might have to figure out yourself how to connect them.
This one is too expensive, Robot Power Products - Open Source Motor Control (OSMC)
And I can't find others right now.
10 and 60 amps.
60 amps at 12V is more like 1hp. (1hp = 740W)
AWOL:
10 and 60 amps.
Thanks. The amperage values were what someone posted on a forum somewhere. 60A would be equivalent of running a 1/2hp on 6V wouldn't it? I know the existing motor controller has a 12V input, but maybe it's actually only allowing up to 6V to the motor.
My guess is the 60A is the locked rotor current + inrush current.
I found Driving a high current DC Motor using an H-bridge - Northwestern Mechatronics Wiki. Since my input is 12V, could I simply lose the dc-dc converter and be ok?
Assuming this circuit would be ok, how would I be controlling it on a arduino? It sounds like to be stationary, I need to write a value of 127 to it? Closer I get to 255 would mean faster in one direction, while closer to 0 would mean faster in the other direction?
Wouldn't it be a lot simpler just to throw in a DPDT switch so you can reverse the leads on the motor?
Chagrin:
Or even something like this with DPDT relays:
Thats a lot of current, I doubt there is a cheap solution using MOSFET H-Bridges.
EDIT: Scratch that, didn't notice the speed control requirement.
Chagrin:
I do think it should be simpler to reverse the leads like that. I'm guessing the schematic I posted is done that way so that only one wire is used to control both direction and speed? Or am I just reading it wrong?
My point was that you already have variable speed in one direction. If you use a DPDT switch on the motor leads to reverse them then you can use the same variable speed to go in the other direction.
