I have tried to do as much research as possible but I am still scratching my head as to how I attack my project.
Which is to light up 10 fence posts each with a 1m strip of ws2812bs running 144 leds per metre.
I have chosen this strip as i would like to eliminate 'spotting' of the leds rebated into the posts, installed in a slim low profile channel with a milky diffuser.
I have tested 60led per m ws2812bs but led seperation is very apparent due to the closeness of the strip to the diffuser.
Please see attached layout sketch
The posts are approximately 1.8m apart but split into a set of 7 posts one side of garden, and 3 posts at the other side of my garage, each cluster approximately 12m apart. The closest of 7 post cluster (post 7) is 5m from the mains socket and the closest of the 3 post cluster (post 8) is 7m from the mains.
Hope the basic sketch helps.
My questions are these,
1 Power distribution -
I already have in my possession 2 x 5v 60a switching power supplies.
Using 1/3 rule at 10a per strip (headroom) will I be able to use these supplies to feed all 10 posts with the distances metioned above?
Thinking in terms of post 1 being the furthest away from mains, could i power 1 to 5 of the 7 post cluster with one psu then 6 and 7 off 1 rail on psu 2 along with 8 to 10 running off rail 2 on psu 2?
What size fuse do i need to install on the mains leads going the 2 power supplies?
Where is the best location for the power supplies, for example near post 7 and post 8 are, or directly at the mains socket. The power supllies are non waterproof so i would have to consider enclosure locations
Is it acceptable to just inject power at each end of each 1m strip or will i need to power midstrip as well?
Is 2.5mm gauge cable enough to link the strips?
2 Control -
The main aim is to have the strips illuminate the garden upon motion detection /dusk to dawn timer but would also like to create a fade in and out and effects for parties.
I need each strip pixels to illuminate from led 1 to 144 at the same time on each post.
How is this achieved?
Motion trigger will be provided by a Phillips Hue outdoor motion sensor as I have a smartthings bridge, a hue bridge and IFTTT and alexa.
I have in my possession a sp108e wifi controller.
I know this can handle the number of leds but can it handle the motion to fade and how do I allocate the pixels?
If it cant be used which arduino would fit the bill?
I realise there are many questions, but feel they relate to the specific task and would appreciate any help with this project, however small.
Many Thanks,
Lex
