You are right, my mistake. However, the LED strip in question is a leftover piece from one I bought months ago and was the excess part that didn't go behind my TV. I don't know the specifications of this LED strip, beside being RGB, and can't figure out how to find them on the strip itself. I would be open to purchasing a specific strip if you could give me some advice.
After some googling I'm back, and I want to update everyone with the solution:
You can power an LED strip with a Pro Micro.
First you have to connect the VCC to the +5V pin, then connect pins 6, 9, 10 each through a 220Ω resistor to the base of three NPN transistors. Next, connect the emitters of the transistors to GND and the collectors to the respective R, G, B pins of the strip.
The caveats expressed by others earlier still apply. 500 mA, MAX, on a USB connector, and you'll need to figure out what the current-per-LED is to ensure you don't exceed that maximum.
Far, far better to use an external power source, if you have one available.
Thank you for the advice! My project is a macro keypad with RGB lighting, and I'm trying to make it as similar as possible to industrially produced models, which typically operate with just one USB cable.
I'm aware of the current limitations of the USB port. As PaulRB mentioned, I should use a maximum of 8 LEDs to avoid exceeding 500 mA. I followed this advice and hope to avoid any damage by keeping everything within safe limits. I'm not sure how to calculate the current per LED exactly, but I'm trying to ensure my project is safe.
I really appreciate your concerns and suggestions!
