Powering a Mini4wd motor with arduino
Hey Guys! Newbye here :slight_smile: I'm approaching Arduino from just a few days and i got an idea that i can't realize. I found in my component's bin an old mini 4wd motor that i'd like to power up to make him move things
( More specs about my project : i'm building a circuit that can close a windows when umidity is upper than a preset value.
Of course i'm experimenting this in a small-scale prototype, )
But i don't know how to interface the mini4wd Motor.
It's a 3V DC brushes motor(usually sourced by batteries) ,but it needs an high current to work properly ( about 1A ).
In the arduino specs i read that every digital pin can source/sink a maximum 40mA current. So i guess i need to use a transistor controlled by the arduino powers source (5v or 3,3 v ) to let an high current reach him ( sourced by a battery pack for example) but i'm not really good with transistor and i don't know how to wire it up.( got BC337 transistors)
So my questions are:
Is my reasoning right ? or can i source my motor directly with the arduino 3,3 V?
How should i wire the transistor up?
A BC337 (NPN transistor) is rated for only 500ma. With just a single transistor you will only be able to drive the motor in one direction. You need an H bridge to drive it bi-directionally.
Good tutorial for transistors: Transistor Circuits | Electronics Club
Inexpensive H-bridge (L293): http://letsmakerobots.com/node/2074
Chagrin:
Thank you for the advice about the transistor, didn't know that before. I'll search for another type of transistor
but the motor just moves in one way ( ok sounds stupid , it closes the "window" but it can't open it back) but i'm just starting over. Do i need the H bridge same way?
If you're only feeding the motor current in one direction (you don't want to be able to reverse the polarity) you do not need an H bridge.
A TIP120 would be a popular transistor of the size you need. Do a web search for TIP120 and you'll find plenty of tutorials.
You will have the fewest problems if you use a motor driver board optimized for low-voltage toy motors.
This inexpensive example will handle two motors and provide bidirectional control: SparkFun Motor Driver - Dual TB6612FNG (1A) - ROB-14451 - SparkFun Electronics
If you just want to learn about current amplification and junction transistor behavior, then go that way and build your own. Or use a logic-level MOSFET transistor - lots of tutorials available for either.
Thank you so much guys!Now ordering all the stuffs i need and then i'll try every way you suggested me :slight_smile:
