Curious question regarding power supply for motors. So I have two 3v motors and I want to power them and control them using an H-Bridge set up of sorts. Maybe I'm not looking at this right but I think I would need 6v to power these motors. Is there a way I can have a power separate power supply and have the Arudino control it? I tried looking this up, but I think my approach is prob not the best.
Post links to the data sheets (or web pages) for the motors and H-bridge.
If your motors are 3V why would you need a 6V supply?
The H bridge is the thing that lets Arduino control the motors from a separate power supply. That's what an H bridge does. Just make sure the grounds are connected.
domtropen:
Those types of small motors are fairly common in small bots, so you should be able to find lots of info. If you use an H-bridge like the L298N based ones, you may need 6v as there may be a couple of volts drop across this type of H-bridge.
The Pololu DRV8833 dual h-bridge works nicely with low voltage motors. I think there is also a single version. The only downside is that it needs two Arduino PWM outputs for each motor if you want forward and reverse. I guess you could run it with a single PWM per motor with some external circuitry.
...R
