Powering an Arduino from 110 AC and Relays Project
Hi folks,
I'm planning to control wirelessly the lights of my house using attiny85 and relays. Since I'm already connecting some part of the circuit (i.e., the relay) to the main power line, i'd like to know if is there any way to power the mc without using an external wall wart adapter. The key point in this project is that I need things to be small, so I can fit them inside the wall switch.
If the power requirement is just a few mA and you are able to insulate the electronics from the user, then it's possible to use a capacitor-rectifier-zener diode arrangement. But as you will be powering relays, you probably need more current than that, unless you can replace the relays by opto triacs. The smallest 5V power supply I found (without trying very hard) was http://uk.farnell.com/myrra/47122/power-supply-2-75w-5vdc-reg/dp/1825773.
carlosraniery:
Hi folks,
In theory, yes there are and there is such circuitry methods published on the web. But I would fall back on the 'if you have to ask you probably shouldn't be messing with it' line. There is always risks of fire and human safety when DIY methods are applied to household power circuits and I try not to encourage such projects but rather suggest you always use fully UL approved components and assemblies for such applications.
Lefty
Thanks for the replies. Probably I will go for the solution posted by dc42.
