So i have been googleing around about powering the arduno with 12 v but i cant seem to find anything. So the question is -Can you power an arduino uno with 12 v dc directly in to Vin?
do you need any regulators or somethin like that?
also will the arduino get fried instantly if i try?
Can i use the barreljack?
On your breadboard you have the red and black strips. Red is positive and black is ground. You have the GND on the red strip and Vin on the Black strip. Not a problem if you remember that this is how you have configured it.
You also have (as far as I can decipher) the VCC of the Relay board connected to the GND of the UNO and the GND of the relay board connected to the Vin of the UNO
See what I'm getting at.
A schematic would be better than a picture of a rats nest
i tried and everything worked except the pushbotton worked as a capacitive sensor?
what should i do? is it the hig voltage? is it dangerous that the regulator is getting a little bit warm?
It seems that you are powering the relay module from the 5volt pin of the Uno.
That setup can't be powered from 12volt, because relays use about 75mA each when active.
Read post#3 again.
A pushbutton acting as capacitive sensor means that you didn't use a pull up resistor with the switch.
The Arduino has buildin pull up resistors, so why not use them.
Connect button between pin and ground, and use this in void setup()
