I'd like to add a USB connection to my current project so a computer and the project can send data to each other via the serial port. I think I can use the FT232, basically cloning the Duemilanove schematic:
My circuit needs more power than USB can provide (3a) so it will always be connected to an external (regulated) source, but I'm not sure I understand how to keep the USB power separated from the circuit power, so they can't damage each other etc.
It looks like the MC33269D is the voltage regulator because a regular Arduino can run from 5-12 volts? I don't think I need that because the external power's already regulated to 5v 3a.
It looks like the LM358D and NDT2955 control powering the circuit from USB or external power? If I know I'll never power the circuit from USB can I just leave all that out?
Is the fuse F1 just to keep the Duemilanove from drawing too much power from the USB host? I don't see one in the schematic for the Nano and since I won't be using host power can I leave it out?
Finally is there anything else I need to do to protect the host from the circuit, and vise-versa?
External power (via connector) requirement is around 7-12 not 5-12.
Yes, you don't need to copy the auto-voltage switching circuit.
Yes, the fuse is to protect from pulling too much current (>500ma) from the host PC. As you are supplying
power via a external voltage source you don't need to protect the PC USB power supply.
No, as long as you aren't drawing current from the USB cable you should not need any extra protection. Note the use of 1k ohm resistors from the FTDI send/rec pins to the AVR rec/send pins, they are a useful isolation method if you need to use pins 0 and 1 for other purposes after you upload your sketch. If you are only going to use pins 0 and 1 for serial communications you don't have to use them.
