Hello everybody,
I have just received my two mentioned boards and I want to power a stepper motor (adafruit 324).
I have installed all the libraries, the IDE, and compiled and loaded the stepper example.
If I use 5V USB power (inserting VIN jumper on Motorshield V2) I see how the stepper works but it seems with a low torque.
Instead of that, if I power the board using a 12V/1A jack and it seems to work ok.
The main doubt that I have is if I want to communicate with the motor using the USB virtual COM port and an external power (in order to have the desired torque).
Is only possible by powering the Arduino uno r3 by usb, removing the VIN jumper (MotorShield) and using the blue VIN (5-12 V) terminal ports?
Because if I plug both (USB and JACK POWER) with VIN jumper inserted (MotorShield), could it damage the board?
Hope your answers, thank you so much
Enrique
