Powering Arduino with another Arduino
Hi all. I am fairly new to arduino so please be kind.
Is it possible to power one arduino with another. I will have two communicating with each other through the rx/tx, but I only want to have one power source.
I am using a sparksfun weather board (basically an arduino on its own) hooked up to an arduino uno. The uno will then run a lcd and have some other sensors connected in. I want to power the whole set-up with a solar panel.
I could, I guess, power both units from the solar panel directly but was just wondering if the uno would be able to provide power to the weather board.
Thanks for any feedback.
if one arduino is functioning normally. then just run 2 wires. one from one of the arduino's 5 volt line to the other arduino's 5 volt line, and one from one ground to the other ground.
if you wanted to power the arduino with one of the other arduino's pin you could use a transistor.
Thanks for that, will give the direct approach a go.
