Hello everyone,
For one of my projects, I would like to power an Arduino Board using a 2-cell (2S) 7.4V LiPo battery. The voltage perfectly falls into the board operating region (so there are no issues here), but my main concern regards how to protect the battery from over-discharging and overcurrents. The battery that I am using (https://hobbyking.com/it_it/turnigy-nano-tech-1200mah-2s-25-50c-lipo-airsoft-pack.html) does not have an integrated protection circuit, so I need to add an external one.
And that's what I did. I bought one of these battery protection boards they sell off Amazon (Youmile 5PCS 2S 3A 7.4V 8.4V Scheda di protezione della batteria al litio 18650 Modulo caricatore BMS Scheda di protezione PCB per cella di batteria al litio agli ioni di litio con striscia di nichel : Amazon.it: Elettronica) and tried it, but I have the following issues:
The board provides charging protection (I don't need that, I want only discharging protection). This is a source of issues since it seems like the board is by default turned off if, as the battery is connected, it is not charged first. So I cannot connect the battery only for discharge, as I would like. (I apparently solved this by short-circuiting the input and output negative terminals, but I have no idea if this affects the behaviour of the board)
The board "needs" all 3 battery terminals (B+, B-, BM), while I have available only B+ and B- (since I do not recharge, I don't care about single-cell control)
So, what I am actually looking for, is a discharging protection board that needs only the two "big" battery terminals, but I cannot find it.
Otherwise, if you have better strategies for powering the Arduino (external buck converter?), I'm all ears.
PS This topic falls into my general problem of "I want to use LiPos to power stuff but I don't know how to implement battery protection". For example, for another project, I would like to power an LED panel with two of these 7.4V batteries in series, but I'm stuck (again) on how to protect them from over-discharging and overcurrents. Also in this case, I would charge the batteries externally using a proper LiPo charger, so I do not mind about the charging but only discharging.
PPS I was thinking about designing my own board, but I'm a mechanical engineer so I don't know where to start. I found some schematics, but I would prefer to find a ready-to-buy board rather than build my own.
Thank you very much in advance
Have a great day!
Luca
