Powering down SD-Card Reader prior to httpupdate
Continuing the discussion from Reading SD Card with ESP32 Troubles:
with my ESP32, I noticed that SD cards were often no longer readable after updates were installed via httpupdate.
I use this function, which at least closes any open file with close() BEFORE starting the update.
void update_firmware() {
    updateMeasuring(false); // In this function currently running measuring is finished and the file is closed via file.close();
    WiFiClientSecure client;
    client.setInsecure();
    t_httpUpdate_return ret = httpUpdate.update(client, link_to_firmware_file);
    switch (ret) {
      case HTTP_UPDATE_FAILED:
        Serial.printf("HTTP_UPDATE_FAILED Error (%d): %s\n", httpUpdate.getLastError(), httpUpdate.getLastErrorString().c_str());
      case HTTP_UPDATE_NO_UPDATES:
        Serial.println("HTTP_UPDATE_NO_UPDATES");
      case HTTP_UPDATE_OK:
        Serial.println("OK");
        const char * httpType PROGMEM = "text/html";
        server.send_P(200, httpType, settingPage);
Does this ensure that everything should run correctly again after the restart (sd.begin() in void setup)? Or would I have to add an SD.end()?
Or what exactly do you mean by "effectivly powering it down, in order to get it to work again"?
