Powering ESP32 Dev Board from the BMS
Hi there! I have a problem with powering ESP32 Dev Board from the BMS and 18650 battery
I use HW373 BMS connected to the ESP's VIN and GND pins via OUT +/- pins. But instead of working normally, is seems like ESP is restarting constantly. I guess it's because that kind of power source is unstable for ESP's brownout detector. How can i make the whole thinkg work? Maybe use a capacitor?
For the context: i am not an expert hardware engineer, it's not my primary field, but i need to find a solution asap
  • Monitor the ESP input voltage to see if it sags.
What board? What model of regulator does it have?
Many boards use AMS1117-33 regulator. These claim to be "low drop-out" but maybe the drop-out is still too high for it to output a steady 3.3V for the ESP32 chip.
An external and truly low drop-out regulator could be used to power the board through it's 3.3V pin. For example MCP1702-33 or HT7333. But you need to consider how much current is needed at 3.3V by your board and any other circuits it powers.
Seems like mine got 117C voltage regulator
It still has more than 1V dropout voltage.
Did you try with 100% charged battery and nothing powered from Esp pins?
An 1117 VR has a 1.3V loss, so the input must be 1.3 + 3.3 which is 4.6 and is 0.4 more than the 18650 can supply. Use two 18650's in series.
I am not connecting directly to 18650, It's connected through BMS OUT pins. Aren't they supposed to give enough voltage?
And i cannot connect two 18650 in series, it'll kill my BMS (trust me and my previous bms killed this way)
It's direct battery voltage anyway. 3.5-4.2V. And the voltage regulator needs ~4.4V to work like it's designed.
Ok, got it. What should i do then? Use DC-DC StepUp?
That's one option, another option was well described on post#3.
It depends on your load, do you power just Esp or some other components attached?
Bye
What BMS, I don't see a BMS in the diagram. Oops, that's right you didn't provide one along with datasheet links for each component.
Why, what happens if it takes a week to find a solution and source parts?
I also have a bunch of sensors attached (GY-21 HTU21, Capacitive Soil Moisture, INA219). Just checked their datasheets, they should work fine with 3.3V. But i also need to power a motor and water pump, and i am not sure how they'll operate from 3.3V (I'm not goind to power them throug ESP directly tho)
I need to submit the project with the deadline being 17 March
Buy a 4 AA battery pack. Connect it to ESP Vin and use it to power your motor and water pump.
Forget the BMS
ESP-WROOM-32 Dev Board
HW373/TP4056 BMS (info here)
It would be nice, but the device must be rechargable, swapping batteries isn't an option :frowning:
Then use 4 or 5 NiMH batteries.
You could use ultra low dropout voltage regulator for your Esp and low-power sensors and power motor/pump directly from battery (TP4056).
