hi everybody, sorry i am asking for your help, i am trying to turn on and off i2c oled display using digital pin using digitalWrite function (pin number, mode) but using digitalWrite (pin number, HIGH) function as switch button pressed OLED display does not show anything but if use digitalWrite (pin number, LOW) if the switch button is not pressed OLED display turns off properly I do not know why, below is the code I ask for your help.
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <SPI.h>
#include <Wire.h>
#include <EEPROM.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH1106.h>
//#include <Fonts/FreeSans12pt7b.h>
//#include <Fonts/Monospaced_bold_10.h>
#include <ArduinoJson.h>
#include "RTClib.h"
RTC_DS3231 rtc;
//Connect with pin 18 and 19
//long lat,lon; // create variable for latitude and longitude object
float lat, lon;
TinyGPS gps; // create gps object
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET 4
Adafruit_SH1106 display(OLED_RESET);
StaticJsonBuffer<200> jsonBuffer;
char deviceID[12] = "METER001";
/* Two "independant" timed events */
const long eventTime_1_TIME = 1000; //in ms
const long eventTime_2_BAT = 1000; //in ms
const long eventTime_3_GPRS = 600000; //in ms
const long eventTime_4_ACCELEROMETER = 1000; //in ms
const long eventTime_5_GPS = 1000; //in ms
/* When did they start the race? */
unsigned long previousTime_1 = 0;
unsigned long previousTime_2 = 0;
unsigned long previousTime_3 = 0;
unsigned long previousTime_4 = 0;
unsigned long previousTime_5 = 0;
volatile int flow_frequency; // Measures flow sensor pulses
// Calculated litres/hour
float vol = 0.0, l_minute;
unsigned char flowsensor = 2; // Sensor Input
//unsigned char flowsensor = A0; // Sensor Input
unsigned long currentTime;
unsigned long cloopTime;
//-- Accelerometer --//
int Contrast = 20;
#define x A1
#define y A2
#define z A6
int xsample = 0;
int ysample = 0;
int zsample = 0;
#define samples 10
#define minVal -50
#define MaxVal 50
const int Buzzer = 8;
//-- End Accelerometer --//
//Voltage Readings//
int analogInput = A3;
float Percentage = 0.0;
float vout = 0.0;
float vin = 0.0;
//float Re1 = 100000;
//float Re2 = 10000;
float Re2 = 10000;
float Re1 = 1000;
int Value = 0;
float Units;
int oledDisplay = 38;
#define BUTTON_PIN 39
const uint8_t DAWASA_LOGO[] PROGMEM = {
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x80, 0x01, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0x00, 0x00, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xf8, 0x03, 0xff, 0xff, 0xc0, 0x3f, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xc0, 0xff, 0x7c, 0xfb, 0xff, 0x03, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xfe, 0x0f, 0xe6, 0xec, 0xdb, 0xdf, 0xf0, 0x7f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xf0, 0x7e, 0xe6, 0xec, 0x35, 0xdb, 0x3e, 0x1f, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xc3, 0xf4, 0xe2, 0x6d, 0xb1, 0xda, 0xf7, 0x83, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0x0f, 0xea, 0x20, 0x6d, 0x8d, 0xb6, 0x63, 0xf0, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xfc, 0x3c, 0xe5, 0x8d, 0xff, 0xff, 0xc7, 0x46, 0x3c, 0x3f, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xf8, 0xee, 0x75, 0x3f, 0xff, 0xff, 0xfc, 0x04, 0xef, 0x1f, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xe3, 0xe6, 0x13, 0xf8, 0x00, 0x00, 0x1f, 0xf0, 0xdd, 0xc7, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0x8f, 0x32, 0x6f, 0x80, 0x7f, 0xfe, 0x01, 0xf3, 0xbb, 0xe3, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0x1f, 0x84, 0x7c, 0x0f, 0xff, 0xff, 0xf0, 0x3f, 0x74, 0xf8, 0xff, 0xff, 0xff,
0xff, 0xff, 0xfe, 0x3f, 0xd3, 0xe0, 0xff, 0xff, 0xff, 0xff, 0x07, 0xe4, 0xbc, 0x7f, 0xff, 0xff,
0xff, 0xff, 0xfc, 0xf1, 0xef, 0x87, 0xff, 0xff, 0xff, 0xff, 0xe1, 0xec, 0xe7, 0x3f, 0xff, 0xff,
0xff, 0xff, 0xf1, 0xda, 0x7e, 0x1f, 0xff, 0xff, 0xf3, 0x83, 0xf8, 0x79, 0x0f, 0x9f, 0xff, 0xff,
0xff, 0xff, 0xe3, 0xed, 0xb8, 0x7f, 0xff, 0xff, 0x80, 0x0f, 0xfe, 0x1e, 0x1f, 0xc7, 0xff, 0xff,
0xff, 0xff, 0xc7, 0x86, 0xf1, 0xff, 0xff, 0xff, 0x10, 0x07, 0xff, 0x8f, 0xbe, 0xe3, 0xff, 0xff,
0xff, 0xff, 0x8f, 0xfb, 0xc7, 0x00, 0x00, 0x00, 0x10, 0x03, 0xff, 0xe3, 0xf0, 0xf1, 0xff, 0xff,
0xff, 0xff, 0x1d, 0xff, 0x8f, 0x00, 0x00, 0x00, 0x00, 0x19, 0xff, 0xf1, 0xe9, 0x39, 0xff, 0xff,
0xff, 0xff, 0x3c, 0x0e, 0x3f, 0x00, 0x01, 0xc0, 0x03, 0x0f, 0xff, 0xfc, 0xf0, 0x7c, 0xff, 0xff,
0xff, 0xfe, 0x77, 0x3c, 0x7f, 0x00, 0x01, 0xc0, 0x19, 0x07, 0xff, 0xfe, 0x7d, 0xee, 0x7f, 0xff,
0xff, 0xfc, 0xf3, 0xb8, 0xff, 0x00, 0x0f, 0xf8, 0x19, 0x37, 0xff, 0xff, 0x18, 0x0f, 0x3f, 0xff,
0xff, 0xf8, 0xe0, 0x31, 0xff, 0x00, 0x1d, 0xfe, 0x1b, 0x3f, 0xff, 0xff, 0x9f, 0x3f, 0x1f, 0xff,
0xff, 0xf9, 0xfc, 0xe3, 0xff, 0x00, 0x18, 0xfc, 0x5f, 0x3f, 0xff, 0xff, 0xcf, 0x79, 0x9f, 0xff,
0xff, 0xf3, 0x80, 0xe7, 0xff, 0x00, 0x18, 0xf8, 0x1f, 0x3f, 0xff, 0xff, 0xe6, 0x01, 0xcf, 0xff,
0xff, 0xe3, 0xc3, 0xcf, 0xff, 0x00, 0x18, 0xf0, 0x1f, 0x9f, 0xff, 0xff, 0xf3, 0x3e, 0xcf, 0xff,
0xff, 0xe7, 0xf3, 0x9f, 0xff, 0x00, 0x38, 0xe0, 0x1f, 0x9f, 0xff, 0xff, 0xf1, 0xb1, 0xe7, 0xff,
0xff, 0xc6, 0x79, 0x1f, 0xff, 0x00, 0x3c, 0xc0, 0x1f, 0xcf, 0xff, 0xff, 0xf9, 0xc4, 0x67, 0xff,
0xff, 0xcf, 0x8b, 0x3f, 0xff, 0x00, 0x3c, 0xc0, 0x1f, 0xc7, 0xff, 0xff, 0xfc, 0xe9, 0xf3, 0xff,
0xff, 0xcc, 0x66, 0x7f, 0xff, 0x00, 0x3e, 0x00, 0x1f, 0xe7, 0xff, 0xff, 0xfc, 0xf1, 0x73, 0xff,
0xff, 0x9f, 0x1e, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x1f, 0xe3, 0xff, 0xff, 0xfe, 0x60, 0xf9, 0xff,
0xff, 0x9c, 0x0c, 0xff, 0xff, 0x00, 0x00, 0x80, 0x1f, 0xf3, 0xff, 0xff, 0xfe, 0x7b, 0x99, 0xff,
0xff, 0x9e, 0x3c, 0xff, 0xff, 0x00, 0x00, 0xf0, 0x0f, 0xf1, 0xff, 0xff, 0xff, 0x36, 0xd9, 0xff,
0xff, 0x3f, 0xcc, 0xff, 0xff, 0x03, 0x80, 0xfe, 0x1f, 0xf1, 0xff, 0xff, 0xff, 0x30, 0xf8, 0xff,
0xff, 0x38, 0x39, 0xff, 0xff, 0x01, 0xc1, 0xff, 0x1f, 0xf0, 0x7f, 0xff, 0xff, 0x18, 0x1c, 0xff,
0xff, 0x3e, 0x39, 0xff, 0xff, 0x07, 0x0f, 0xf9, 0x9e, 0x00, 0x00, 0x7f, 0xff, 0x98, 0x0c, 0xff,
0xff, 0x3f, 0x99, 0xff, 0xff, 0x00, 0xf3, 0xce, 0x20, 0x00, 0x00, 0x7f, 0xff, 0x9e, 0x6c, 0xff,
0xfe, 0x30, 0x79, 0xff, 0xff, 0x00, 0x1e, 0x38, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x9c, 0x9c, 0xff,
0xfe, 0x7e, 0x39, 0xff, 0xff, 0x00, 0x01, 0xc0, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x98, 0xfc, 0xff,
0xfe, 0x70, 0x33, 0xff, 0xff, 0x00, 0x00, 0x1f, 0xc0, 0x00, 0x00, 0x7f, 0xff, 0x9e, 0x0c, 0xff,
0xfe, 0x7f, 0xb3, 0xff, 0xff, 0x00, 0x03, 0xff, 0xc0, 0x00, 0x00, 0x7f, 0xff, 0x9c, 0x3e, 0x7f,
0xfe, 0x7f, 0xf3, 0xff, 0xff, 0x00, 0x00, 0xfb, 0x80, 0x00, 0x00, 0x7f, 0xff, 0x9f, 0xfe, 0x7f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xcf, 0x9f, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0x80, 0x07, 0xfc, 0x07, 0xe0, 0xe0, 0x78, 0x3f, 0x03, 0xfe, 0x00, 0x3f, 0xe0, 0x7f, 0xff,
0xff, 0x80, 0x01, 0xf8, 0x03, 0xe0, 0xe0, 0x30, 0x7e, 0x01, 0xfc, 0x18, 0x1f, 0xc0, 0x3f, 0xff,
0xff, 0x83, 0xc0, 0xf0, 0x43, 0xf0, 0x40, 0x30, 0x7c, 0x00, 0xfc, 0x00, 0xff, 0x80, 0x1f, 0xff,
0xff, 0x83, 0xe0, 0xf0, 0xc1, 0xf0, 0x02, 0x00, 0xf8, 0x30, 0x7e, 0x00, 0x1f, 0x06, 0x0f, 0xff,
0xff, 0x83, 0xe0, 0xe0, 0x00, 0xf8, 0x06, 0x00, 0xf0, 0x00, 0x3f, 0xf8, 0x0e, 0x00, 0x07, 0xff,
0xff, 0x80, 0x01, 0xc0, 0x00, 0x7c, 0x07, 0x01, 0xe0, 0x00, 0x18, 0x1c, 0x0e, 0x00, 0x03, 0xff,
0xff, 0x80, 0x03, 0x83, 0xf0, 0x3c, 0x0f, 0x81, 0xc0, 0xfc, 0x0e, 0x00, 0x3c, 0x1f, 0x81, 0xff,
0xfc, 0xff, 0xfd, 0xff, 0xff, 0xff, 0xfd, 0xff, 0xdf, 0x77, 0xff, 0xff, 0xfb, 0xff, 0xff, 0xff,
0xff, 0x57, 0xdb, 0xee, 0xd6, 0x2d, 0xed, 0xf2, 0x5e, 0x66, 0xd9, 0x5d, 0xb9, 0xe1, 0xac, 0xff,
0xff, 0x46, 0x1d, 0x9a, 0x2a, 0x11, 0x0e, 0x4c, 0x86, 0x72, 0x23, 0x52, 0x59, 0x5a, 0xc9, 0x3f,
0xf9, 0x06, 0xce, 0x00, 0x3a, 0x51, 0x7e, 0x04, 0x96, 0x38, 0x24, 0x52, 0x54, 0x26, 0x09, 0x3f,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xfd, 0xf6, 0xf7, 0xf7, 0xff, 0xfd, 0xff, 0xff, 0xff, 0x7f,
#if (SH1106_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SH1106.h!");
#endif
void flow () // Interrupt function
flow_frequency++;
Serial1.begin(9600);
pinMode(oledDisplay, OUTPUT);
digitalWrite(oledDisplay, HIGH);
pinMode(BUTTON_PIN, INPUT_PULLUP);
EEPROM.get(4, vol);
EEPROM.get(0, Units);
DynamicJsonBuffer jsonBuffer;
delay(3000); // wait for console opening
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (rtc.lostPower()) {
Serial.println("RTC lost power, lets set the time!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
for (int j = 0; j < samples; j++)
xsample += analogRead(x);
ysample += analogRead(y);
zsample += analogRead(z);
xsample /= samples;
ysample /= samples;
zsample /= samples;
pinMode(flowsensor, INPUT);
digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
attachInterrupt(digitalPinToInterrupt(flowsensor), flow, RISING); // Setup Interrupt
//attachPinChangeInterrupt(digitalPinToInterrupt(flowsensor), flow, RISING); // interrupt connected to pin A0
currentTime = millis();
cloopTime = currentTime;
display.begin(SH1106_SWITCHCAPVCC, 0x3C);
//display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3C (for the 128x32)// Check your I2C address and enter it here, in Our case address is 0x3C
display.clearDisplay();
display.drawBitmap(0, 0, DAWASA_LOGO, 128, 64, WHITE); // display.drawBitmap(x position, y position, bitmap data, bitmap width, bitmap height, color)
display.display();
delay(4000);
display.display(); // this command will display all the data which is in buffer
display.setTextColor(WHITE, BLACK);
//display.setFont(&Monospaced_bold_10);
//display.drawRect(117, 25, 3, 3, WHITE); // Put degree symbol ( ° )
draw_text(68, 0, "BAT =", 1);
draw_text(120, 0, "V", 1);
draw_text(0, 0, "L/M =", 1);
draw_text(0, 30, "UNTS =", 1);
DateTime now = rtc.now();
/* Updates frequently */
unsigned long currentTime = millis();
byte buttonState = digitalRead(BUTTON_PIN);
/* This is my event_1 */
if ( currentTime - previousTime_1 >= eventTime_1_TIME) {
display.setTextSize(1);
// display.setFont(&Monospaced_bold_10);
//display.setCursor(0, 0);
//display.print(daysOfTheWeek[now.dayOfTheWeek()]);
char currentDate [16];
uint8_t thisDay, thisMonth ;
thisDay = now.day();
thisMonth = now.month();
sprintf (currentDate, "%02d/%02d/", thisDay, thisMonth); //add leading zeros to the day and month
display.setCursor(62, 15);
display.print(currentDate);
display.setCursor(102, 15);
display.print(now.year(), DEC);
/*================Display Time================*/
char buffer [16];
uint8_t thisSec, thisMin, thisHour;
thisSec = now.second();
thisMin = now.minute();
thisHour = now.hour();
sprintf (buffer, "%02d:%02d:%02d", thisHour, thisMin, thisSec);
display.setCursor(0, 15);
display.print(buffer);
/* Update the timing for the next event*/
previousTime_1 = currentTime;
/* This is my event_2 */
if ( currentTime - previousTime_2 >= eventTime_2_BAT) {
Value = analogRead(analogInput);
vout = Value * (5.0 / 1024.0) * 2;
//vin = vout / (Re2 / (Re1 + Re2));
//Percentage = map(vin, 7.4, 8.6, 0, 100);
Percentage = vout;
display.setCursor(102, 0);
display.print(Percentage, 0);
//display.print(rtc.getTemperature());
display.display();
previousTime_2 = currentTime;
if (currentTime >= (cloopTime + 1000))
cloopTime = currentTime; // Updates cloopTime
if (flow_frequency != 0) {
// Pulse frequency (Hz) = 4.8Q, Q is flow rate in L/min.
l_minute = (flow_frequency / 4.8); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
display.setCursor(32, 0);
display.print(l_minute);
l_minute = l_minute / 60;
display.setCursor(40, 30);
vol = vol + l_minute;
Units = vol / 1000.0;
display.print(Units, 4);
flow_frequency = 0; // Reset Counter
EEPROM.put(4, vol);
EEPROM.put(0, Units);
display.display();
else {
display.print(flow_frequency);
EEPROM.put(4, vol);
display.display();
//delay(5000);
digitalWrite(oledDisplay, LOW);
if (buttonState == LOW) {
if (buttonState == HIGH) {
if ( currentTime - previousTime_3 >= eventTime_3_GPRS) {
Send_Data();
previousTime_3 = currentTime;
if ( currentTime - previousTime_4 >= eventTime_4_ACCELEROMETER) {
Accelerometer();
previousTime_4 = currentTime;
if ( currentTime - previousTime_5 >= eventTime_5_GPS) {
//display.clearDisplay(); // clearing the display
displayInfo();
display.display();
previousTime_5 = currentTime;
while (Serial1.available()) { // check for gps data
if (gps.encode(Serial1.read())) // encode gps data
gps.f_get_position(&lat, &lon); // get latitude and longitude
display.setCursor(2, 36);
display.print(lat, 6);
display.setCursor(74, 36);
display.print(lon, 6);
/*else{
display.setCursor(2, 26);
display.print("*.******");
display.setCursor(74, 26);
void draw_text(byte x_pos, byte y_pos, char *text, byte text_size) {
display.setCursor(x_pos, y_pos);
display.setTextSize(text_size);
display.print(text);
display.display();
void ShowSerialData()
while (Serial.available() != 0)
Serial.write(Serial.read());
void Send_Data()
if (Serial.available())
Serial.println("AT");
Serial.println("AT+SAPBR=3,1,\"Contype\",\"GPRS\"");
delay(6000);
ShowSerialData();
Serial.println("AT+SAPBR=3,1,\"APN\",\"internet\"");//APN
delay(6000);
ShowSerialData();
Serial.println("AT+SAPBR=1,1");
delay(6000);
ShowSerialData();
Serial.println("AT+SAPBR=2,1");
delay(6000);
ShowSerialData();
Serial.println("AT+HTTPINIT");
delay(6000);
ShowSerialData();
Serial.println("AT+HTTPPARA=\"CID\",1");
delay(6000);
ShowSerialData();
JsonObject& object = jsonBuffer.createObject();
object.set("deviceID", deviceID);
//object.set("map_link",http://maps.google.com/maps?&z=15&mrt=yp&t=k&q=lat+lon);
object.set("batteryStatus",Percentage);
object.set("Units", Units);
object.set("Latitude", lat, 6);
object.set("Longitude", lon, 6);
object.printTo(Serial);
Serial.println(" ");
String sendtoserver;
object.prettyPrintTo(sendtoserver);
delay(4000);
Serial.println("AT+HTTPPARA=\"URL\",\"http://mis.dawasa.go.tz/amr_system/data.php\""); //Server address
delay(4000);
ShowSerialData();
Serial.println("AT+HTTPPARA=\"CONTENT\",\"application/json\"");
delay(4000);
ShowSerialData();
Serial.println("AT+HTTPDATA=" + String(sendtoserver.length()) + ",100000");
Serial.println(sendtoserver);
delay(6000);
ShowSerialData();
delay(6000);
ShowSerialData;
Serial.println("AT+HTTPACTION=1");
delay(6000);
ShowSerialData();
Serial.println("AT+HTTPREAD");
delay(6000);
ShowSerialData();
Serial.println("AT+HTTPTERM");
delay(10000);
ShowSerialData;
Serial.println("AT+SAPBR=0,1"); // Close GPRS context
delay(300);
ShowSerialData;
Serial.println("");
delay(300);
void Accelerometer() {
int value1 = analogRead(x);
int value2 = analogRead(y);
int value3 = analogRead(z);
int xValue = xsample - value1;
int yValue = ysample - value2;
int zValue = zsample - value3;
//condition for tampering detection
if (xValue < minVal || xValue > MaxVal || yValue < minVal || yValue > MaxVal || zValue < minVal || zValue > MaxVal)
digitalWrite(Buzzer, HIGH);
delay(200);
digitalWrite(Buzzer, LOW);
//GPSMessage();
void displayInfo()
display.print(lat,6);
display.print(lon,6);
