Powering l298n
Is it safe to power a l298n shield direclty from the arduino using it's 5v pin? Or I need to use an external power supply? I'm using 5.9V DC motors.
Cesaario:
You can power the shield using the 5V pin. You can NOT power the motors using the 5V pin.
For that, you absolutely MUST have an external power supply.
So I can't do this, right?
Instead, I should do this? Replacing the 12v source to a 6v since i'm using 5,9v motors.
Right. You can't power the motors using the Arduino's voltage pin. Motors suck way too much current.
Yes.
