Powering LEDs when using Vin w/battery (Arduino Nano)
Hmm, so based on the math found on this thread's best answer, I'm ballparking the Nano current draw to be approx 33.4mA.
And then also this thread's best answer, it appears that I can draw 100mA from a new CR2032 cell.
If I ran just the Nano and a single LED (a configuration I also tested), and estimated LED at 40mA (not super bright so likely less than 40), my current draw should be roughly 73.4mA in this configuration. I also have two CR2032's in series. In this configuration, the single LED did not light up either. Is this rough test/assessment valid?
Are there other ways to get around this, with using the CR2032? The advantage of the CR2032 is the small space/volume.
