Powering Mini DC Air Pumps and Heating Pads using Arduino Uno
I'm working on a project that requires the use of air pumps (4.5V) and heating pads (5-12V). I'm attempting to power it with an Arduino Uno, but I guess I'm limited.
Reading the forums gives me the idea to use MOSFETs to drive the pumps, but I'm not able to understand how. I need to run at least two pumps, one for inflation and one for deflation.
The heating pads, on the other hand, are only faintly heating, and I need to connect two or more of them together to produce heat.
I do have MOSFET and RELAY modules from Tinkerkit if it would be of any help. I am new to the world of electronics, so guidance in form of relevant articles or videos will be beneficial in moving forward.
Thanks!
Generally an Arduino can control things, but for anything pulling much current it can't power them - you must provide separate power. You can use MOSFETS or relays to switch the power - search the forum for many many examples of their use.
