Hi! i could use successfully a motor using a positive supply with a diode and a TIP120 transistor and arduino. But now i have a new challenge, to run the motor using negative supply GND and -9v, because my knowledge of electronics is limited a dont know what transistor will do the trick. Im sure its something easy but i cant find anything searching.
Does that mean that you cannot use the =9V section of the supply at all?
"Powering (a) motor." Does that mean simply ON and OFF?
Derok:
so...any way to do this?
You could place the motor between -9V and GND easily using a relay.
A simple relay circuit shouldn't be any great burden on the +9 section.
The relay contacts would switch the "-9V" to the motor.
