Hi everyone there
How are you all,
I am trying to make an Entry Point Alarm System with Arduino Nano Sensing with HC-SR04 interfacing with nRF24L01 and Piezo Buzzer (Disk) and would like to power it by 3.7v 280mAh 1.04wh charging with TP4056 powered by 6V 1W Solar Cell … [The Project is still on Paper]
Now
My question is the Battery I have 3.7v 280mAh 1.04wh will be able to power all these
nRF24L01
Supply current in TX mode @ 0dBm output power :- 11.3 mA
Supply current in RX mode @ 2000 kbps :- 12.3 mA
Supply current in Power Down mode :- 900 nA
HC-SR04
Quiescent Current :- <2mA
Working Current :- 15mA
Arduino Nano
Power Consumption :- 19 mA
is the TP4056 is sufficient to Charge the 3.7v 280mAh 1.04wh Battery by the 6v/1w Solar Cell
what else do I need to know more about this Project before assembling it
or if I use ESP8266-12e then
its The ESP8266 usually draws a peak current of about 250mA after it wakes up
and then more or less constantly draws around 70mA before it goes back to sleep
what will be the Smallest Battery I can use to Power the Project
Please Help
