Powering Sensors
Hi everyone, brand new to Arduino but have messed about with a Micro:bit with my daughter in the past and understand basic electrical systems. I've had a look at the suggested posts on this topic but not found the answer.
I am building an automated plant watering system which will have an Arduino board, 4 capacitive moisture sensors, 1 board with 4 relays and 4 motors. Came from AliExpress.
The sensors are 3.3v and I wondered what is the best way to power these? Can the 3.3v output on the Arduino only power one of these? It is unclear what voltage the motors require although it looks to be either 3 or 4.5v.
I have a 9v battery pack (6 x AA batteries) which will power the motors via the relays, but unsure if I can also power the sensors.
Ultimately it'll only read the sensors once every few hours, run the motor(s) for a few seconds if needed and then go back to waiting. But it could be that 4 motors could run at the same time and all 4 sensors would be powered as well. If the sensors could be turned off when not being read that'd be handy.
Cheers
  • Use an external 3v3 power supply; you could look at a buck converter.
  • Always show us a good schematic of your proposed circuit.
    Show us good images of your ‘actual’ wiring.
    Give links to components.
  • Consider an RTC in your design.
  • The software can be written so only one motor runs at a time.
  • In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch. Use the < CODE / > icon from the ‘posting menu’ to attach the copied sketch.
Thanks LarryD. Is that one external 3v3 per sensor?
I'll post up photos and schematics once I've put them together.
Cheers
Which of the 2 dozen or so different Arduinos?
  • Post your schematics before things get made.
  • One 3v3 power supply powering all.
There are dozens if not hundreds of these garden watering projects in this forum, in the project hub and on the internet.
The motors have to have their own power supply.
The sensors are probably ok, check datasheet for the board to see what max pin current is and compare to sensor.
Motors will probably need a wall wart PSU.
Ok, so have progressed somewhat and now hit an odd problem. I am using a Leonardo R3 controller.
As suggested, I bought a Buck voltage regulator (SparkFun Buck Regulator Breakout - 3.3V (AP63203) | The Pi Hut)
I am powering this from a 5V USB mains charger and have monitored the output using a multimeter and it sits at a constant 3.33v, so I assume this is working as expected.
For the time being I'm not looking at the motors, I'm simply getting the code and sensor working.
I connected the VCC and Gnd of the capacitive moisture sensor to the 3.3v and gnd pins of the Leonardo respectively. I then connected the AOUT of the sensor to an analogue pin of the Leo. I should add the specs of the sensor state it can accept 3.3v or 5v input and has a voltage regulator onboard.
At this point everything works wonderfully. I get consistent readings from the sensor.
But, when I go to power the sensor from the Buck board, using the Buck's VOUT and Gnd for the sensor, I get hugely sporadic values delivered. Sometimes correct, sometimes nothing at all.
So I assume the issue has to be the power supply as it works perfectly on the controller supply. I have tried different USB chargers, all 5V, to see if it helps, but it hasn't. I have tried a direct 5V input to the sensor as well, but the same issue.
Any ideas?
