Powering servo from 12V motorcycle batery
Hi, I'm quite new to elettronics and I need some help.
What I want to do is to power this servo using my motorcycle lithium battery.
The servo has to be operated by pushing a button.
Searching online i understanded that i need a Buck converter like this, to reduce the motorcycle battery voltage to power the arduino (nano) . I know however that i cannot power the servo from the arduino but i need a separate power supply. What do you suggest? fell free to recommend also different compontents, but keep in mind i need it to be has small as possible.
Also, the bike doesn't have an ingition key, so if i plug all directly to the battery will it train much?
Right, use another buck converter for the servos.
Or step the voltage down to the servo voltage (6.8V?) and feed it also into the Arduino's on-board regulator (Uno barrel jack).
Buck converters have become really inexpensive like these for example. Personally I would just go with a couple of buck converters. Just make sure the converters will meet your voltage and current needs. Fancy buck converters include both Voltage and Current displays for In and Out.
Ron
