I have the following AI-thinker A6 module
I would like to power it with a 3.7V lithium battery. I will also be powering a pro mini 3.3v arduino with the battery. Of course, I would like to get the most out of the battery. The system will be triggered on by a RTC and a small circuit once per day. Read 4 sensors, send a text message and then shut back off.
It looks like the ai-thinker has a voltage regulator on it for a 5.0V input. I know the chip runs on lower voltage. If I apply less voltage to the regulator, will it drop out and just bypass the voltage? Is there a way to bypass it? Should I use a boost regulator? The other option would be two 3.7v batteries connected in series, is this safe?
Thank you,
Anthony
