Powering the Yun with an external battery
Is it possible to safely power a Yun with a 9V battery by connecting it to the Vin and GRD pins?
I've done this in the past with an UNO and had no problems, but I don't know if there is any differences with the Yun?
If this is not safe can someone recommend the best way to power the Yun with a battery? I'm looking to power the board and two servo motors.
Thanks
rhammell:
NO! The a Yun has is no on-board regulator, VIN must only be clean regulated 5V power. Your battery will destroy your Yun.
Use a much bigger battery, and feed it with a DC-DC converter. The Yun is not designed for energy efficiency, the WiFi radio and the faster Linx processor will drain a rectangular 9V (transistor radio) battery in less then an hour.
Maybe THIS would work with a large rechargeable battery (sealed lead acid or an RC car battery pack?)
Thanks for this info. Glad to hear this before I ended up testing it out for myself and ruining my board!
The link you included should definitely be helpful as well - i think I'll end up getting one of these.
Thanks again!
