Powering Two Vibration Motors
I have designed a circuit using the arduino nano which should control two vibration motors. The motors and arudino are all powered by a single 9v battery. When I send a signal to pin 9 of the arduino, it sends an ouput voltage to pins 2 and 3. These pins are connected to NPN transistors which, when they receive a voltage, should open their gates and allow the battery power to turn on the motors. The motors are each connected in parallel with a capacitor and an LED to protect them, as was advised on several forums I read when constructing the circuit. The problem I am having is that sometimes, when I send a signal to pin 9, both motors will turn on, while more often, when I send the signal only the first motor will turn on. I do not believe this is a hardware or power issue, as I have checked all of the hardware and wiring very carefully and, as I mentioned before, the whole circuit works sometimes. I am wondering whether it is possible that the reduced output signal corresponds to a reduced input signal. It is possible that sometimes the signal to pin 9 is a little bit under 5v, while other times it is 5v. Does the arduino output a signal proportional to the input signal? If so, how might I modify my code to correct for this? If not, what might be causing my problem? I have included my code below and have attached a picture of the circuit and motor datasheet.
NOTE: In the attached picture, the battery and motors are missing from the circuit. The battery is connected across the red and black wires on the left (I now have a proper battery connector, so that is not the source of the issue) and each motor is are in parallel to a capacitor and LED.
CODE:
int switchPin = 9;
int val;                     // variable for storing value of switchPin
  // initialize digital pins 02 and 03 as outputs.
  pinMode(02, OUTPUT);
  pinMode(03, OUTPUT);
  // initialize digital pin 09 as input.
  pinMode(9, INPUT);
  val = digitalRead(switchPin);
  if (val==HIGH) {            // if pin 09 receives a voltage
    digitalWrite(02, HIGH);   // turn vibration motor 1 on
    digitalWrite(03, HIGH);   // turn vibration motor 2 on
    digitalWrite(02, LOW);    // turn vibration motor 1 off
    digitalWrite(03, LOW);    // turn vibration motor 2 off
I was unable to attach the datasheet for the motors, but it can be found at: https://catalog.precisionmicrodrives.com/order-parts/product/310-117-10mm-vibration-motor-3mm-type
A 9V battery is not suitable for powering motors, not even tiny little vibration motors.
Even when the motors are rated at 3 volts?
What kind of battery would be more suitable?
Thank you.
Something capable of more than 20mA and more like 3V
