i guess it might be a stupid or silly question but i dont know
what will happen if we connect both usb cable and a dc battery to the arduino which source will be chosen?
It depends on what arduino you have, the newer ones will switch automatically to a battery if you have it, the older ones you need to change a link to choose what source of power to use.
i have the new one
duemilanove
that fixes my problem then when powered from the usb it didnt have a atandard v ref so i had some trouble with a few analouge sensor
and i was scared to conect both battery and usb i thought some thing would blow up :o
How come? That doesn't make sense.
i didnt have a standars v ref i was fluctuating when powered via usb
now does it make sence?
yeah i know that uno is the new one ![]()
but i think itz not released yet is it ?
If you are running external power, then check the voltage at the +5v pin to see what it acually is. I have a chinese DFRobot clone board that, when externally connected to 9v, the 5v pin reads ~7.5v.
The reference voltage on an arduino is connected to the supply voltage. This is fine for most cases where the signal is related to the supply as well, like measuring a pot. When it will give you variations is if you are measuring a voltage not related to the supply voltage, like from a battery.
If this is important you can either use an external regulated reference voltage or switch over to the internal 1v1 reference.
thanks ![]()
