when I try to run any lcd example, the screen will show nothing unless I set the number of lines in lcd.begin to 1 (or 0), if I do lcd.begin(20,4) (its a 20*4) screen, the screen doesnt show anything, but if I do lcd.begin(20,1) it shows. What's wrong?
Read floresta's responses on this thread:
http://arduino.cc/forum/index.php/topic,51198
I suspect you didn't connect a potentiometer, connected it wrong or adjusted it wrong.
Done!, what hapened this time is that this display uses negative voltage for contrast adjust, so you have to slightly modify the tutorial on lcd screens, you haver to attach -5 v to one side of the potentiometer, gnd to the other side, and the middle pin goes to the contrast adjust (pin 3 of the lcd screen) but anyway, thanks for your fast answer!
Now I will have to find a way to supply -5 volts to the potentiometer, because right now Im doing it using an atx power supply haha
If you research the letters after 'PC2004' you will probably find that you have an extended temperature display and these frequently require a negative voltage.
Don
