Hello to all,
I have begun a project regarding the making of the prototype printed circuit board (PCB).
You can visit the address below, for more information!
With regards,
Stamatopoulos Prodromos
Thank you!!!
Hello to all,
With regards,
Thank you!!!
Note: This is an IndieGoGo fundraising campaign
It appears to be a case full with UV lamps on the inside for exposing photo-resist PCB or photo-resist silkscreen mask. Included is a silkscreen printing frame and an etching tank.
Yes, and now we make some discount 45% for the full "PPCB Maker" suitcase.
we have 3 different type of “PPCB Maker” .
1)"PPCB Maker" suitcase , A4 board size, with full UV lamps (total 200W) up and down inside in suitcase, air pump vacuum, USB connections , expose photosensitive board and also silkscreen frame, and make dry the soldering and curable mask.
2)"PPCB Maker" lite , A4 board size, UV lamps (40W)in bottom inside suitcase , air pump vacuum,.
3)”PPCB Maker” small, A5 board size, UV lamps (40W) in bottom insite suitcase,.
Thank you
