I have built this project, it working fine but there are two problem I'm facing
1.Unit recharge limited to two digits (units does not exceed 99 units)If I recharge more than 99,it resets to lower number.
example if I send sms with #1000* the system does not accept it, returns 0 recharged.
other number is being accepted like #52*,#99* etc
2.Units is being reduced after every single pulse from meter, instead of every 3200 pulses.
Circuit diagram
here is the code
#include <EEPROM.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);
int led = 13;
#define pulsein 8
#define relay 12
unsigned int pusle_count = 0;
float units = 0;
unsigned int tk = 0;
float watt_factor = 0.3125;
unsigned int temp = 0, i = 0, x = 0, k = 0;
char str[70], flag1 = 0, flag2 = 0;
String bal = "";
lcd.begin(16, 2);
pinMode(led, OUTPUT);
pinMode(pulsein, INPUT);
pinMode(relay, OUTPUT);
digitalWrite(pulsein, HIGH);
lcd.setCursor(0, 0);
lcd.print("Automatic Energy");
lcd.setCursor(0, 1);
lcd.print(" Meter ");
delay(2000);
lcd.clear();
lcd.print("Welcome");
delay(2000);
lcd.clear();
lcd.print("GSM Initilizing...");
gsm_init();
lcd.clear();
lcd.print("System Ready");
Serial.println("AT+CNMI=2,2,0,0,0");
init_sms();
delay(2000);
send_data("SmsSystem Ready");
send_sms();
digitalWrite(led, LOW);
lcd.clear();
// EEPROM.write(1,0);
// tk=EEPROM.read(1);
serialEvent();
tk = EEPROM.read(1);
units = tk / 5.0;
lcd.print("Units:");
lcd.print(units);
lcd.print(" ");
if (tk < 15)
lcd.print("LOW Balance:");
lcd.print("Balance:");
lcd.print(tk);
lcd.print(" ");
read_pulse();
check_status();
if (temp == 1) {
decode_message();
send_confirmation_sms();
void serialEvent()
while (Serial.available()) {
char ch = (char)Serial.read();
str[i++] = ch;
if (ch == '*') {
temp = 1;
lcd.clear();
lcd.print("Message Received");
void init_sms()
Serial.println("AT+CMGF=1");
delay(200);
Serial.println("AT+CMGS=\"+255xxxxxxxxxx\"");
delay(200);
Serial.println("AT+CRES");
delay(2000);
Serial.println("AT+CSQ");
delay(2000);
void send_data(String message)
Serial.println(message);
delay(200);
void send_sms()
Serial.write(26);
void read_pulse()
if (!digitalRead(pulsein)) {
digitalWrite(led, HIGH);
//count++;
//units=watt_factor*count/1000;
if (units < 1) {
units--;
tk = units * 5;
EEPROM.write(1, tk);
while (!digitalRead(pulsein))
// delay(2000);
void check_status()
if (tk > 1) //change hoise 15 to 1
digitalWrite(relay, HIGH);
flag1 = 0;
flag2 = 0;
if (tk < 1 && flag1 == 0) //change hoise 15 to 1
lcd.print("LOW Balance ");
init_sms();
send_data("Energy Meter Balance Alert:");
send_data("Low Balance\n");
Serial.println(tk);
delay(200);
send_data("Please recharge your energy meter soon.\n Thank you");
send_sms();
message_sent();
flag1 = 1;
if (tk < 5 && flag2 == 0) {
digitalWrite(relay, LOW);
lcd.clear();
lcd.print("Light Cut Due to");
lcd.print("Low Balance");
delay(2000);
lcd.clear();
lcd.print("Please Recharge ");
lcd.print("UR Energy Meter ");
init_sms();
send_data("Energy Meter Balance Alert:\nLight cut due to low Balance\nPlease recharge your energy meter soon.\n Thank you");
send_sms();
message_sent();
flag2 = 1;
void decode_message()
x = 0, k = 0, temp = 0;
while (x < i) {
while (str[x] == '#') {
x++;
bal = "";
while (str[x] != '*') {
bal += str[x++];
x++;
bal += '\0';
void send_confirmation_sms()
int recharge_amount = bal.toInt();
tk += recharge_amount;
lcd.clear();
lcd.print("Energy Meter ");
lcd.print("Recharged:");
lcd.print(recharge_amount);
init_sms();
send_data("Energy Meter Balance Alert:\nYour energy meter has been recharged Rs:");
send_data(bal);
send_data("Total Balance:");
Serial.println(tk);
delay(200);
send_data("Eelctricity Has Been Connected\nThank you");
send_sms();
temp = 0;
i = 0;
x = 0;
k = 0;
message_sent();
void message_sent()
lcd.clear();
lcd.print("Message Sent.");
void gsm_init()
lcd.clear();
lcd.print("Finding Module..");
boolean at_flag = 1;
while (at_flag) {
Serial.println("AT");
//delay(1000);
while (Serial.available() > 0) {
if (Serial.find("OK"))
at_flag = 0;
lcd.clear();
lcd.print("Module Connected..");
lcd.clear();
lcd.print("Disabling ECHO");
boolean echo_flag = 1;
while (echo_flag) {
Serial.println("ATE0");
echo_flag = 0;
lcd.clear();
lcd.print("Echo OFF");
lcd.clear();
lcd.print("Finding Network..");
boolean net_flag = 1;
while (net_flag) {
Serial.println("AT+CPIN?");
if (Serial.find("+CPIN: READY"))
net_flag = 0;
lcd.clear();
lcd.print("Network Found..");
lcd.clear();
