Precision measurement position in 1D
I am trying to measure the position, in 1D, of a pin as it protrudes from a flat surface. The measurement needs to made as a function of time at a rate of 1 kHz and the total travel of the pin will not exceed 0.050 inches.
I need help finding an appropriate sensor, I have thought about using linear scales that are used in digital readout (DRO) systems but am not sure they are fast enough to achieve 1,000 readings a second.
In this case the pin is the firing pin of a rifle and the work is to try and identify factors that increase the precision of the rifle for accuracy competitions.
TIA for any help offered,
wade
Hi, @wwbrown
Can you please tell us what your project is?
Over what distance range are you aiming to measure?
Why such a fast update rate?
Thanks..Tom.. :smiley: :+1: :coffee: :australia:
What's the application?
I know SKF uses, self designed sensors measuring nanomemeters. Would not be too difficult to copy.
Consider high speed, short range laser distance sensors. One company's offerings. The AR200 looks appropriate.
If mechanical contact is allowed this link should help. Leader in Digital Electronic Indicators There are many different configurations etc available.
Try searching for "electronic surface gauge"
