precisiOn servo relay control
Hi all,
I am trying to use the arduino for precision control of a servomotor. I’m a bit new to servo controlling so I am hacking up the sample servomotor code from the ITP. What I’d like to be able to do is to send the Arduino data (e.g. keypresses) via Processing to position the servomotor.
So for example, if I press ‘a’, I want to position the servo to 0’ and if I press ‘z’ I want it to be at about ‘180’
However, I can’t get my head around how to send the proper pulses to the motor to get it to go to different positions and stay there. I can get it to increment via a loop and can increase the increments, or go to positions based on digital in, but that is about it, and I’ve just been guessing. Also any hints on sending data to Arduino via Processing would be cool!
Any ideas would be really helpful! Thanks!!
-Bagder
THE CODE:
int servoPin = 3; // Control pin for servo motor
int pulse = 0; // Amount to pulse the servo
int counter=0;
int destination;
long lastPulse = 0; // the time in milliseconds of the last pulse
int refreshTime = 20; // the time needed in between pulses
int inPin = 7;
int val=0;
pinMode(servoPin, OUTPUT); // Set servo pin as an output pin
pinMode(inPin, INPUT);
Serial.begin(19200); // FOR DIAGNOSING
if (destination<1400){
pulse=500;
}else{
pulse=1500;
if(counter<destination){
if (millis() - lastPulse >= refreshTime) {
digitalWrite(servoPin, HIGH); // Turn the motor on
delayMicroseconds(pulse); // Length of the pulse sets the motor position
digitalWrite(servoPin, LOW); // Turn the motor off
lastPulse = millis(); // save the time of the last pulse
counter++;
counter=0;
// THIS CODE TO BE REPLACED BY KEYPRESS CODE AT SOME POINT
val=digitalRead(inPin);
if (val==1){
destination=2400;
destination=400;
Serial.println(destination);
