Muchas gracias!
Pude cambiar los pines, estas son las dos clases que estoy trabajando para probar:
MotorClass
// Simple Motor Shield sketch
#include <Servo.h>
// Arduino pins for the shift register
#define MOTORLATCH 12
#define MOTORCLK 4
#define MOTORENABLE 7
#define MOTORDATA 8
// 8-bit bus after the 74HC595 shift register
// (not Arduino pins)
// These are used to set the direction of the bridge driver.
#define MOTOR1_A 2
#define MOTOR1_B 3
#define MOTOR2_A 1
#define MOTOR2_B 4
#define MOTOR3_A 5
#define MOTOR3_B 7
#define MOTOR4_A 0
#define MOTOR4_B 6
// Arduino pins for the PWM signals.
#define MOTOR1_PWM 4
#define MOTOR2_PWM 3
#define MOTOR3_PWM 6
#define MOTOR4_PWM 5
#define SERVO1_PWM 2
//#define SERVO2_PWM 9
// Codes for the motor function.
#define FORWARD 1
#define BACKWARD 2
#define BRAKE 3
#define RELEASE 4
// Declare classes for Servo connectors of the MotorShield.
Servo servo_1;
int incomingData = 0; // for incoming serial data
Serial.println("Clase Motor iniciada");
// Use the default "Servo" library of Arduino.
// Attach the pin number to the servo library.
// This might also set the servo in the middle position.
servo_1.attach(SERVO1_PWM);
//delay(2000);
//Websetup();
// send data only when you receive data:
if (Serial.available() > 0)
// read the incoming byte:
incomingData = Serial.read();
incomingData = (incomingData - '0');
//Serial.println(incomingData, DEC);
if( incomingData == 1)
//servo_1.write(180);
// say what you got:
Serial.println("Motor encendido");
// Suppose there is a relay, or light or solenoid
// connected to M3_A and GND.
motor_output(MOTOR3_A, HIGH, 255);
delay(2000);
//motor_output(MOTOR3_A, LOW, 255);
incomingData = 2;
if( incomingData == 2)
Serial.println("Motor apagado");
//Motor off
incomingData = 0;
// motor
// Select the motor (1-4), the command,
// and the speed (0-255).
// The commands are: FORWARD, BACKWARD, BRAKE, RELEASE.
void motor(int nMotor, int command, int speed)
int motorA, motorB;
if (nMotor >= 1 && nMotor <= 4)
switch (nMotor)
case 1:
motorA = MOTOR1_A;
motorB = MOTOR1_B;
case 2:
motorA = MOTOR2_A;
motorB = MOTOR2_B;
case 3:
motorA = MOTOR3_A;
motorB = MOTOR3_B;
case 4:
motorA = MOTOR4_A;
motorB = MOTOR4_B;
default:
switch (command)
case FORWARD:
motor_output (motorA, HIGH, speed);
motor_output (motorB, LOW, -1); // -1: no PWM set
case BACKWARD:
motor_output (motorA, LOW, speed);
motor_output (motorB, HIGH, -1); // -1: no PWM set
case BRAKE:
// The AdaFruit library didn't implement a brake.
// The L293D motor driver ic doesn't have a good
// brake anyway.
// It uses transistors inside, and not mosfets.
// Some use a software break, by using a short
// reverse voltage.
// This brake will try to brake, by enabling
// the output and by pulling both outputs to ground.
// But it isn't a good break.
motor_output (motorA, LOW, 255); // 255: fully on.
case RELEASE:
motor_output (motorA, LOW, 0); // 0: output floating.
default:
void motor_output (int output, int high_low, int speed)
int motorPWM;
switch (output)
case MOTOR1_A:
case MOTOR1_B:
motorPWM = MOTOR1_PWM;
case MOTOR2_A:
case MOTOR2_B:
motorPWM = MOTOR2_PWM;
case MOTOR3_A:
case MOTOR3_B:
motorPWM = MOTOR3_PWM;
case MOTOR4_A:
case MOTOR4_B:
motorPWM = MOTOR4_PWM;
default:
// Use speed as error flag, -3333 = invalid output.
speed = -3333;
if (speed != -3333)
// Set the direction with the shift register
// on the MotorShield, even if the speed = -1.
// In that case the direction will be set, but
// not the PWM.
shiftWrite(output, high_low);
// set PWM only if it is valid
if (speed >= 0 && speed <= 255)
analogWrite(motorPWM, speed);
void shiftWrite(int output, int high_low)
static int latch_copy;
static int shift_register_initialized = false;
// Do the initialization on the fly,
// at the first time it is used.
if (!shift_register_initialized)
// Set pins for shift register to output
pinMode(MOTORLATCH, OUTPUT);
pinMode(MOTORENABLE, OUTPUT);
pinMode(MOTORDATA, OUTPUT);
pinMode(MOTORCLK, OUTPUT);
// Set pins for shift register to default value (low);
digitalWrite(MOTORDATA, LOW);
digitalWrite(MOTORLATCH, LOW);
digitalWrite(MOTORCLK, LOW);
// Enable the shift register, set Enable pin Low.
digitalWrite(MOTORENABLE, LOW);
// start with all outputs (of the shift register) low
latch_copy = 0;
shift_register_initialized = true;
// The defines HIGH and LOW are 1 and 0.
// So this is valid.
bitWrite(latch_copy, output, high_low);
// Use the default Arduino 'shiftOut()' function to
// shift the bits with the MOTORCLK as clock pulse.
// The 74HC595 shiftregister wants the MSB first.
// After that, generate a latch pulse with MOTORLATCH.
shiftOut(MOTORDATA, MOTORCLK, MSBFIRST, latch_copy);
delayMicroseconds(5); // For safety, not really needed.
digitalWrite(MOTORLATCH, HIGH);
webClient
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "xxxx..com.ar"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192,168,0,177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
void Websetup() {
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
// Make a HTTP request:
client.println("GET /twitter.php?cmd=on HTTP/1.1");
client.println("Host: xxx.com.ar");
client.println("Connection: close");
client.println();
Serial.println("connected");
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed: retry...");
webConnect();
void webConnect()
client.println("Host: xxxx.com.ar");
client.println();
void Webloop()
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while(true);
Ya funcionan en "paralelo", el tema es que cuando cargo el setup de WebClient deja de funcionar automaticamente el motor, me parece que es debido #define MOTORLATCH 12, que cambiando el numero el motor no funciona de ninguna forma, actualmente tengo conectado el DC Motor en M3 del motorShield.
Recien empiezo la verdad y no me quedan muy claras algunas cosas.
Muchas gracias!
Saludos,
Ger.
