Preliminary investigation of the uM-FPU V3.1 device
I was alerted to the existence of this in another thread:
http://arduino.cc/forum/index.php/topic,98133
I ordered one of the 32-bit chips (Floating Point Co-Processor uM-FPU v3.1) from Sparkfun for $US 19.65.
Manufacturer’s page:
http://www.micromegacorp.com/index.html
It’s an 18 leg DIP chip, with straightforward wiring requirements. For SPI, just MOSI, MISO, SCK, +5V and Gnd. Plus tying a few of the other pins either to +5V or Gnd.
In its default configuration it doesn’t need slave select (SS) however you can configure it to do so, if you need to use other SPI devices as well.
The supplied Arduino library and demo sketch worked as advertised, displaying things like a simple graph of a sine wave.
The big questions are: how fast is it? is it easy to use?
The default speed of the processor in the chip is 29.48 MHz, which is almost twice the clock speed of the normal Arduinos.
However offset against that is the need to communicate with the chip, although SPI is pretty fast. You basically send (via SPI) simple “commands” like “load register 1 with literal 10”, “add register 1 to register 2”, “retrieve register 2”.
Test of calculating sines:
#include <SPI.h>
#include <Fpu.h>
#include <FpuSerial.h>
  Serial.println("Nick FPU test");
  SPI.begin();
  Fpu.begin();
  if (Fpu.sync() == SYNC_CHAR)
    FpuSerial.printVersionln();
    Serial.println("FPU not detected");
    while(1) ; // stop if FPU not detected
unsigned long start1, end1, start2, end2;
volatile  float result;
#define RESULT  1                       // uM-FPU register
  float rad;
  start1 = micros ();
  for (rad = 0.0; rad < 3.0; rad += 0.1)
    Fpu.write(SELECTA, RESULT);
    Fpu.write(FWRITE0);
    Fpu.writeFloat(rad);
    Fpu.write(FSET0, SIN);
  end1 = micros ();
  start2 = micros ();
    result = sin (rad);
  end2 = micros ();
  Serial.print (end1 - start1);
  Serial.println (" uS for maths chip.");
  Serial.println ();
  Serial.print (end2 - start2);
  Serial.println (" uS for inbuilt.");
  Serial.println ();
  Serial.println("Done.");
  while(true)
}  // end of loop
Results:
Nick FPU test
uM-FPU V3.1.2
2572 uS for maths chip.
3572 uS for inbuilt.
Done.
In this case the FPU chip gave a reasonable speed increase (72% of the execution time).
Trying division however:
// same setup as above ...
volatile float foo;
volatile float bar = 424242;
  start1 = micros ();
  for (foo = 1.0; foo < 1000.0; foo++)
    Fpu.write(FWRITE0);
    Fpu.writeFloat(foo);
    Fpu.write(FSET0, FWRITE0);
    Fpu.writeFloat(bar);
    Fpu.write(FDIV0);
  end1 = micros ();
  start2 = micros ();
    result = foo / bar;
  end2 = micros ();
  Serial.println ();
  Serial.println ();
  while(true)
}  // end of loop
Results:
124228 uS for maths chip.
42628 uS for inbuilt.
Exponentiation doesn’t seem faster either:
    Fpu.write(FWRITE0);
    Fpu.write(FSET0, EXP);
    result = exp (foo);
85360 uS for maths chip.
36528 uS for inbuilt.
Mind you, 85350 uS for the chip is probably mostly the 1000 lots of SPI sending the command and getting the result. In fact I’m a tiny bit skeptical about the results for the inbuilt maths, they seem a bit fast.
(to be continued)
Precision
This particular chip has 32-bit registers internally, so it will be able to handle longs and normal floats (not doubles). Thus you wouldn't get it for 8-byte double precision. However the manufacturers do have a 64-bit version (not sure of the cost of that).
Ease of use
To be honest, using the thing isn't the simplest thing in the world. It is more-or-less like Assembler programming ... "load register", "add", "store".
However they do supply an IDE environment (Windows only) that takes things like this:
RESULT EQU F1
deg VAR FLOAT
RESULT = SIN ( DEGREES (deg))
And turn it into:
//-------------------- uM-FPU Register Definitions -----------------------------
//-------------------- Variable Definitions ------------------------------------
float deg;                              // float variable
//-------------------- Generated Code ------------------------------------------
    // RESULT EQU F1
    // deg VAR FLOAT
    // RESULT = SIN ( DEGREES (deg))
    Fpu.write(FWRITE0);
    Fpu.writeFloat(deg);
    Fpu.write(FSET0, DEGREES, SIN);
So that simplifies using it a bit.
Probably the big time saving would be if you wanted to do parallel processing. Particularly for something time-consuming like sines/cosines etc., because the chip can be doing that in the background while you are doing something else like taking readings.
SPI compatible interface up to 15 MHz
Try... SPI.setClockDivider( SPI_CLOCK_DIV2 );
Good idea.
Before:
Add that line:
  SPI.begin();
  SPI.setClockDivider( SPI_CLOCK_DIV2 );  // faster SPI
  Fpu.begin();
After:
Hmmm.
Let’s investigate. We did Fpu.begin ():
void UMFPU::begin(void)
  begin(SS_PIN);
And begin() does:
void UMFPU::begin(byte pin)
  // initialize the chip select
  _cs = pin;
  digitalWrite(_cs, HIGH);
  pinMode(_cs, OUTPUT);
  reset();
Which is kind of strange because I’m not using chip select.
#define SS_PIN    10
Looks like I’m using pin 10 whether I like it or not.
And reset() does:
void UMFPU::reset()
  digitalWrite(_cs, LOW);
  // disable SPI.Master
  SPI.end();
  // reset the FPU
  digitalWrite(MOSI_PIN, HIGH);
  for (byte i = 0; i < 80; i++)
    digitalWrite(SCK_PIN, HIGH);
    digitalWrite(SCK_PIN, LOW);
  digitalWrite(MOSI_PIN, LOW);
  delay(10);
  // enable SPI.Master
  SPI.setDataMode(SPI_MODE0);
  SPI.setBitOrder(MSBFIRST);
  SPI.setClockDivider(SPI_CLOCK_DIV4);
  SPI.begin();
Aha! It sets the clock divider. And calls SPI.begin().
So why do their examples call SPI.begin()?
Well, we’ll fix that:
  SPI.begin();
  Fpu.begin();
Fooled them! Now to test it …
Nick FPU test
FPU not detected
Looks like that clock speed isn’t supported.
Does this work…
SPI.begin();
Fpu.begin();
SPI.setClockDivider( SPI_CLOCK_DIV4 );
I presume it will because the code above had:
in it.
So far then it looks like it's faster for sines but way slower for divisions, in that case there's no point using the chip unless you can make use of the parallel processing it offers.
Based on that (and assuming the other trig functions are fast) if you had a trig-intensive application that properly pipelined the actions of asking for data and using the data it might be good. Also if you had some constants loaded into these "registers" that would save a few operations I assume.
I think I've seen the Picaxe guys talking about this, it would certainly make sense for them.
Rob
Hi Nick,
Good work (again !),
Q: The chip also has a 12bit ADC, did you get that working?
That would make the chip interesting as one could connect e.g. a thermister or so and do
in arduinish based upon - http://arduino.cc/playground/ComponentLib/Thermistor2 -
double Thermister() {
 int rawADC = analogRead(1)
 double Temp = log(((40960000/RawADC) - 10000));
 Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
 Temp = Temp - 273.15;            // Convert Kelvin to Celcius
 Temp = (Temp * 9.0)/ 5.0 + 32.0; // Convert Celcius to Fahrenheit
 return Temp;
The "only thing" to do is to start the conversion-routine and read back the value of the temp register..
Q: is it possible to store code on the Fpu and reuse it ...(my implicit assumption above) --update -- A: It also provides Flash memory and EEPROM for storing user-defined functions (from the man. webpage)
..fyi - they used dspic30F3012 (18pin, 16bitter, 30MIPS) for that fpu chip, at least in the past.. you may take a pic32mx2xx in dip28 (or any newer pic24, dspic33), add the microchip math libs (ie those within the C30, C32 compilers) and SPI slave, and you will be faster :)
robtillaart: Q: is it possible to store code on the Fpu and reuse it ...(my implicit assumption above)
I believe so, not that I have done it. That would be one of the major advantages - you could store quite a complex calculation, feed in a couple of parameters, and have it work it out.
Of course, you could do a similar thing with a second Atmega328, I suppose it depends on your application.
I also have the um-fpu V3.1 and tried timing it against the Arduino code and was getting similar odd results. I changed the divider in the fpu reset function to DIV2 and it compiles and works for me. I also modified Nick's FPU code slightly to this:
    Fpu.write(SELECTA, RESULT);   // 4
    Fpu.write(FWRITEA);           // 5
    Fpu.write(FWRITE0);           // 5
    Fpu.write(FDIV0);         // 20
    Fpu.wait();
The number in the comment is the execution time in microseconds for that instruction as specified in Appendix B of the datasheet. The write instructions don't wait for the result to complete and if you write more than 256 instructions you might get weird results. The Fpu.wait() waits until the instructions have executed. This slows it down even more but is a more realistic comparison. This fpu code writes the first value into the A register, the second value into register zero and then divides register A by register zero. With the DIV2 clock, the code is faster but not enough to overtake the Arduino. The FPU takes 130780 vs. 42620 with the built-in code.
I also timed that code when using a multiply instead of divide in both loops and got 124384ms for the FPU but the built-in code was 21124ms. This makes no sense. The FPU should be able to do a multiply much faster than it can do a divide and the divide has to be faster than what the Arduino can do in software. The fpu instructions are 12 bytes long. Sending those 12 bytes to the fpu with DIV2 (clock is at 8MHz) should take about 12 microseconds and the execution time of the actual fpu instructions should add another 34 microseconds. So once through the loop should take about 46 microseconds and a thousand times around should take about 46 milliseconds.
Something is really wrong!
Pete
Ah yes, good point about the wait. Now I feel a bit silly. Of course, without waiting you are pumping stuff out to the chip faster than it can do it. So with the last test (exponentiation) the results now are:
110016 uS for maths chip.
For calculating sines:
5436 uS for maths chip.
For division:
144212 uS for maths chip.
42620 uS for inbuilt.
This is with the standard SPI, not the DIV2 one.
Even the above tests are a bit unfair because I added the Fpu.wait() but didn't read the results back. So that would have added a bit more time to get the result back into the main chip.
To be fair to the chip manufacturers I would be pleased to hear in what way my tests are not correct. On the face of it though, you aren't saving any time (on these particular tests) using it.
I can't believe that the normal Uno can do 1000 sines in 3572 uS. That's a sine calculation in 3.572 uS! (57 clock cycles). Despite my use of volatile they must be being optimized away. I'll look into that some more.
Oops. The sine test was only 30 iterations. (0.0 to 3.0 by 0.1 intervals). So that's 30 sine calculations in 119 uS each. That's 1905 clock cycles. I suppose that's believable.
…attached is the MCHP document with number of cycles for floating point math, which is most probably (99.9% :slight_smile: ) included in that fpu chip you investigate…
… ie.: that uM-FPU V3.1 chip (dspic30F3012) and 32bit floating point function calc @29MIPS takes
SIN ~2238cycles = ~77usecs
MUL ~109cycles = ~3.76usecs
DIV ~361cycles = ~12.45usecs
dspic30float.pdf (479 KB)
But the Arduino loop was also 30 iterations so the performance ratio still hold.
pito: SIN ~2238cycles = ~77usecs
OK, so 77 + around (10 * 4) for sending the instructions, is around 117 * 30 iterations = 3510 uS. That's reasonably close to the observed.
I can't really explain why the division is so slow.
Another data point. I used the PlainFFT package to do an FFT of 64 32-bit floating point data samples on the Arduino Nano (328). It produces the result in 19.3 milliseconds. The uM-FPU FFT instruction can do a 64 point FFT in 8.7 microseconds. If my timing is correct (5 usecs per byte), you can transfer the 64 floating point numbers to the uM-FPU in 1.3 milliseconds, so sending the data, doing the FFT and getting the data back should take around 2.6 milliseconds. When I get around to it, I'm going to do the same FFT on the uM-FPU so that I can measure how long it takes.
Pete PlainFFT is available at: http://code.google.com/p/makefurt/source/browse/trunk/arduino-libraries/PlainFFT/
"..The uM-FPU FFT instruction can do a 64 point FFT in 8.7 microseconds.." - this is almost impossible, maybe 8.7msecs..
Seems to me that using SPI to lash two Arduinos together would allow you to achieve almost identical results with the added advantage of a easy-to-use compiler and IDE.
For me, the argument for these sorts of chips is negated somewhat by the appearance of platforms like the Maple that allow you to deploy some serious horsepower, if needed, to crunch through math with very high precision.
maybe 8.7msecs..
Oooooops. I was out by three orders of magnitude! Thanks for the correction.
Pete
