Premier projet débutant, pleins de question !
Bonjour,
Je souhaiterais débuter mon tout premier projet sur un arduino uno, mais j’ai plein de question, voilà l’idée :
Je souhaiterais avoir une chasse d’eau automatique (grâce à un sensor à ultrason) et un petit servo lié a la chasse d’eau.
Matériel :
Arduino Uno
Senseur ultrason SR04
Servo
Un petit bout de “breadboard” (circuit en français ?)
Une petit led de statut
Voilà le code
#include <Servo.h> //This line is needed to use the servo library
Servo servo1; //This line create a servo named "servo1"
int buffer; //two more integer variables we will use as buffers
const int pingPin = 3, led = 4; //This is an variable we are setting to 3 and 4 to make it easier to read/write from those pins
  servo1.attach(2); //set the servo to pin 2
  pinMode(led, OUTPUT); //set the led pin as an output
  Serial.begin(9600); // initialize serial communication, this will let us read/write data back and forth (this is useful for debugging)
  long duration, inches; // establish variables for duration of the ping, and the distance result in inches
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  pinMode(pingPin, INPUT); //Set the pingPin to an input to read from
  inches = pulseIn(pingPin, HIGH)/ 74 / 2; //read from the pin, divide by 74 to account for the speed of sound, then by 2 to account for the return trip)
  if (inches<20) flusher(); //if the reading is less than 20 start the flush function
  else //if the reading is not less than 20
    buffer--; //decrease the buffer
    if (buffer<0) buffer=0; //make sure the buffer cant be less than 0
    servo1.write(360); //put the servo in the far right position
    digitalWrite(led, LOW); //turn off the LED
  delay(100); //wait a 10th of a second before checking again
void flusher()
  buffer++; //increase the buffer counter
  if (buffer>15) //if the buffer counter is over 15 (which would be 1500 or 1.5 seconds)
    servo1.write(41); //put the servo in the far left position
    digitalWrite(led, HIGH); //turn the led on
    delay(1000); //wait one second
    delay(3000); //wait 3 second
    buffer=0; //reset the buffer
La question maintenant, j’ai trouvé ce code sur la vidéo d’un type sur youtube. Mise à part que l’unité est en inches (pas trop un soucis, je peux faire la conversion et laisser l’unité en inches), le code vous semble-t-il ok ?
Mise à part la distance, ainsi que le temps d’action du servo quelles autres variables dois-je modifier ?
Quelle partie du code dois-je modifier pour le temps d’action du servo ?
Que me conseillez-vous pour alimenter mon arduino ? (Hors secteur) piles 9v ? batteries AA (si oui combien ?), batterie externe (celles utilisée pour les telephones)
L’idéale pour moi serait une batterie externe type téléphone (facilement re-chargeable) mais j’ai vu qu’il fallait un minimum de mA pour ne pas que la batterie se mette en pause. Pensez-vous que mon senseur ultrasonic consomme suffisament ?
Merci d’avance pour vos réponses
ce qui est étrange, il y a une variable duration mais elle n'est pas utilisée...
pour la durée d'action, tu as les delays a changer...
nicolasweber8:
Je souhaiterais avoir une chasse d'eau automatique (grâce à un sensor à ultrason) et un petit servo lié a la chasse d'eau.
Rhoooo, c'est si compliqué d'appuyer sur le bouton avec le doigt ?
M'enfin, pourquoi pas ...
hazerty565:
Est-ce que ce délais est vraiment celui pendant lequel le servo "tire" la chasse ? Ou est-ce la partie
" servo1.write(41); //put the servo in the far left position
delay(1000); //wait one second"
biggil:
Pour nous humain, oui, mais j'ai un chat dressé pour faire ces besoins dans les WC (véridique), malheureusement, impossible de lui apprendre à tirer la chasse (...essayé...), donc pas très agréable les surprises dans les WC :slight_smile: (Mieux tout de même que de devoir rammasser la litière cependant !)
nicolasweber8:
wow ! joli coup :slight_smile:
Pour l’alim, peut être une pile 9volts ? Même s’il faudra la changer souvent, ça prends pas de place et c’est facile à trouver.
Merci pour les réponses,
J'ai également créer un post sur la partie principale en anglais car mon code a du un peu changer, en effet le code originale était avec un sensor 3 pin, alors que celui que je possède est un 4 pin (echo, etc..)
Mon prochain problème, comment empêcher la chasse de fonctionner AVANT que l'objet ne sorte du champ ? quelle fonction utiliser ?
