Hi group,
I am working on a char function that returns a array that consists of the input array wiht a premise character.
But the compiler errors on this line: STROUT[i] = STRIN[i - d];
(error= invalid types 'char[int]' for array subscript)
I am not a C++ expert so how to solve this.
char strIn[] = "123.5";
const unsigned int PRRE_BUFLEN = 5;
Serial.println( premise(PRRE_BUFLEN, "3.5", '0' ) );
char premise( int MAXLEN, char STRIN, char TOKEN ) {
//start function
char STROUT[MAXLEN];
int s = strlen(STRIN);
int o = strlen(STROUT);
int d = o - s;
for ( int i = 0 ; i <= d - 1 ; i++ ) {
STROUT[i] = TOKEN;
for ( int i = d ; i <= o - 1 ; i++ ) {
return STROUT;
Scroll up in the error messages, the original error is that the 2nd argument to your premise function is a char, but you are passing it a const char*.
There are other problems.
You are returning a local variable that goes out of scope as soon as the function exits.
You declare the char array STROUT, but do not initialize it, so strlen(STROUT) will use whatever randomly happens to be in memory at that location.
strlen determines the length of a string by looking for the string terminator character (0x00);
You can't return an array as such from a function. You can however pass one into a function, and arrays are always passed by reference.. so you can update these parameters.
Also... don't forget to terminate your new string with the null character.
Try the following...
char strIn [10] = "3.57";
char strOut[10] = {0};
while(!Serial);
premise(8, strIn, strOut, '0' );
Serial.println(strOut);
void premise( int lenOut, char inStr[], char outStr[], char filler)
int lenIn = strlen(inStr);
int d = lenOut - lenIn;
for ( int i = 0 ; i < d ; i++ )
outStr[i] = filler;
for ( int i = d ; i < lenOut ; i++ )
outStr[i] = inStr[i - d];
outStr[lenOut] = 0x00;
As I would like the function to return a array a global STROUT is not practibal, but other suggestions are usefull, so I changed the code a bit:
char premise( int MAXLEN, char STRIN, char* TOKEN ) {
//start function
char STROUT[MAXLEN] = {0};
int o = MAXLEN;
int d = o - s;
STROUT[i] = TOKEN;
STROUT[i+1] = '\0';
return STROUT;
But now I get a error (invalid types 'char[int]' for array subscript) on this:
but both array are declared and also are i and d. So this error makes no sense to me
STRIN is a single character, the compiler does not like you treating it as an array.
TOKEN is being used as if it is a single char, but you are telling the compiler that it is a pointer to a char array.
You CAN NOT return a local variable from the function. Returning STROUT actually returns a pointer to the location of STROUT, which is created on the stack when the function is called. If any other functions are called afterwards, or an interrupt occurs (such as for the millis() timer, servicing the serial hardware, etc) then the STROUT array data will be overwritten. You can return STROUT if you declare it 'static', which essentially turns it into a global variable, but you cannot do that with a variable size array.
I missed that in your last code, but no, you cannot return an array from a char function, a char function returns a char. You can return a char*, but the pointer cannot be to a local variable that will cease to exist when the function ends. There are a lot of string manipulating functions, such as strcpy, strcat, etc, that take a char array as an argument, then pass a pointer to that same array back as the return value. There are also functions that declare a static char array inside the function, then return a pointer to that char array - that is possible because a static char array persists after the function exits, but can only be directly accessed inside the function, and cannot vary in size dependent on an argument passed to the function.
Returning a 'static' works as long your function doesn't need to be reentrant-safe and the array size is fixed at compile time.
Otherwise, have the calling function pass the array into the called function (via pointer) along with the array's length. The latter can then fill it with data.
I did not understand what you were trying to do. I though you were just trying to add a single character at the beginning of the string. You are actually padding to the left of the string with the specified character.
