I am having issues with Arduino 1.0.6 on a Mac (10.10.1).
It appears that the preprocessor is not recognizing my struct.
I am getting the following error:
Arduino: 1.0.6 (Mac OS X), Board: "Arduino Uno"
ChristmasArc:13: error: 'RGB' has not been declared
ChristmasArc:13: error: 'RGB' does not name a type
ChristmasArc.ino: In function 'void loop()':
ChristmasArc:48: error: 'nColor' was not declared in this scope
#include <math.h>
#include <Arduino.h>
//Definitions
#define PIN 6
struct RGB {
byte red;
byte green;
byte blue;
//Globals
float x1, x2, y1, y2, persistence;
int octaves;
boolean niceMood; // true = nice and false = naughty
unsigned int naughty, nice;
RGB nColor; // noisey RGB
// Initialize library
Adafruit_NeoPixel ring = Adafruit_NeoPixel(16, PIN, NEO_GRB+NEO_KHZ800);
void setup(){
nice = true;
ring.begin(); // initialize library
ring.show(); // off
persistence = 0.5;
octaves = 3;
// test series
colorWipe(ring.Color(255, 0, 0), 50);
colorWipe(ring.Color(0, 255, 0), 50);
colorWipe(ring.Color(0, 0, 255), 50);
colorWipe(ring.Color(0,0,0), 0);
// set up fist color
// Naughty is reddish and nice is cyanish
naughty = 0; // red
nice = 180; // cyan
void loop(){
// calculate noise
int noise;
int hue;
x1 = float(millis())/100.0;
y1 = 10.0;
for (uint16_t i=0; i<ring.numPixels(); i++){
noise = int(PerlinNoise2(x1, y1, persistence, octaves)*60);
hue = ((niceMood)? nice : naughty) + noise;
if (hue < 0) hue += 360;
hue2rgb((unsigned int)hue, &nColor);
ring.setPixelColor(i, ring.Color(nColor.red, nColor.green, nColor.blue));
ring.show();
void colorWipe(uint32_t c, uint8_t wait){
//incrementally color the lights...
for(uint16_t i=0; i < ring.numPixels(); i++){
ring.setPixelColor(i, c);
ring.show();
delay(wait);
No, your struct will not work as you have it, and exactly as your error message says.
You declare your struct and only give it a tag name, so when you wish to create a variable of struct type RGB you need to tell it, it is a struct or change your definition to a typedef struct.
So, your code will need to look like this for it to compile:
In C you would be correct. According to the C++ standard struct is identical in semantics with class you can change them at will. The ONLY difference between struct and class is that a struct defaults to public: whereas class defaults to private:
So is the Arduino preprocessor treating struct as a c-struct not a c++ struct?
BTW-- changing to struct RGB colors; gives the same errors.
struct RGB {
byte red;
byte green;
byte blue;
RGB myrgb;
RGB myrgb;
I suspect the "RGB" is already defined in one of those .h file. Try changing its name.
