I am having difficulty getting an led toggle state to work with NO_KEY instead of digitalRead. Currently I am toggling an led on and off by pressing and holding a button for 3 seconds to change the state of the led. That is working correctly, but when I want to drive it using any button from my matrix keypad via a shift register, NO_KEY just loops the led on and off.
Any help would be appreciated.
#include <Keypad_MC17.h>
#include <Keypad.h> // GDY120705
#include <Wire.h>
#define I2CADDR 0x20
#include "LedControl.h" // need the library
LedControl lc = LedControl(12, 11, 10, 1); //LedControl(int dataPin, int clkPin, int csPin, int numDevices=1);
byte val[8][8] = {0};
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'0', '1', '2', '3'},
{'4', '5', '6', '7'},
{'8', '9', 'A', 'B'},
{'C', 'D', 'E', 'F',}
byte rowPins[ROWS] = {0, 1, 2, 3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {4, 5, 6, 7}; //connect to the column pinouts of the keypad
byte row;
byte col;
byte matchCol;
byte matchRow;
//initialize an instance of class NewKeypad
Keypad_MC17 customKeypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS, I2CADDR);
const int pinLED = 13;
const int pinSwitch = 2;
byte currSwitch, lastSwitch;
unsigned long timeStart;
bool bCheckingSwitch;
bool ledState;
// Wire.begin( );
customKeypad.begin( ); // GDY120705
lc.shutdown(0, false); // turn off power saving, enables display
lc.setIntensity(0, 8); // sets brightness (0~15 possible values)
lc.clearDisplay(0);// clear screen
pinMode( pinLED, OUTPUT );
digitalWrite( pinLED, LOW );
pinMode( pinSwitch, INPUT_PULLUP );
lastSwitch = digitalRead( pinSwitch );
bCheckingSwitch = false;
ledState = false;
char customKey = customKeypad.getKey();
for (row = 0; row < 4; row++)
for (col = 0; col < 4; col++)
if (hexaKeys[row][col] == customKey)
matchCol = col;
matchRow = row;
//read the switch (for simplicity, no debouncing done)
//currSwitch = customKeypad.getKey();
currSwitch = digitalRead( pinSwitch );
//if the switch is low now and doesn't match its
//previous reading, it means the switch has changed
//either unpressed-to-pressed or pressed-to-unpressed
if ( currSwitch != lastSwitch )
//if low now, the change was unpressed to pressed
if ( currSwitch == LOW )
//in that case, get the time now to start the
//5-sec delay...
timeStart = millis();
//...indicate we're now timing a press...
bCheckingSwitch = true;
//ledState = false;
}//if
//was a rising edge (button being released)
//cancel checking the switch timing now since
//it's not being held hown
//ledState = false;
}//else
//and save the
lastSwitch = currSwitch;
}//if
//if we haven't seen a rising edge, keep checking the
//timing
if ( bCheckingSwitch )
//if the millis count now is 5000 or more higher
//than it was when the press was detected (timeStart),
//turn on the LED
if ((millis() - timeStart ) >= 3000 ) {
if (ledState == false) {
digitalWrite( pinLED, HIGH );
ledState = true;
delay(3000);
else {
ledState = false;
delay(3000);
}//if
if (customKey != NO_KEY) {
Serial.println(matchRow);
Serial.println(matchCol);
if (customKey != NO_KEY && val[matchRow][matchCol] == 0) {
val[matchRow][matchCol] = 1;
lc.setLed(0, matchRow, matchCol, true);
customKey = NO_KEY;
delay(200);
if (customKey != NO_KEY && val[matchRow][matchCol] == 1) {
val[matchRow][matchCol] = 0;
lc.setLed(0, matchRow, matchCol, false);
customKey = NO_KEY;
delay(200);
