Press button to control LED ON AND OFF
i have to do a project to make my LED flash when push button pressed and push button not pressed =LED off
i try a code like this
const int buttonPin = 16; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
// turn LED off:
digitalWrite(ledPin, LOW);
but it does not work. Then i ask my friend he give me this code(below) and he told me i will understand the difference between his code and my code .but i really don't understand what mistake i make
// Initialize serial and wait for port to open:
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
// Set pins
pinMode(LED_Out_Pin, OUTPUT);
pinMode(SW_In_Pin, INPUT_PULLUP);
how is pinMode different?
It is hard to know what is going on without a schematic or the rest of the code but it appears that one program sets the mode for the button pin to INPUT (the state after a reset and would require a pulldown resistor according to the code) and the other program sets the mode for the button pin to INPUT_PULLUP (and presumably the code acts on a LOW instead of on a HIGH).
here is the schematic
schematic of what? Why did you choose pin 16?
schematic of PCB
here is the photo
aarg:
i just see the schematic and guess it is pin 16..
With a schematic such as that, a lot of guessing would be needed.
I used to be an electrical engineer for about forty years and left voluntarily. If I had provided a schematic such as that, I would have had to worry about my continued employment.
