Press button to counter increment
I tried to use the mills() to instead of delay(),
I pushed the buttonState to High and the time is reach the condition,but how it can't work...
if ((buttonState == HIGH) && (currentMillis - previousMillis >= OnTime)){
if ((buttonState == LOW) && (currentMillis - previousMillis >= OffTime)){
#include <Four7Seg74hc595.h>
* PRESS BUTTON COUNTER INCREMENT
esl::Four7Seg74hc595 display( 10,9,8 );
// Pin connected to Pin 14 of 74HC595 (Data=DIO,arduino pin8)
// Pin connected to Pin 12 of 74HC595 (Latch=RCLK,arduino pin9)
// Pin connected to Pin 11 of 74HC595 (Clock=SCLK,arduino pin10)
char sbuf[5];
uint16_t Counter;
uint32_t  ts1,ts2 ,ts3 ,ts4 ,ts5;
const int buttonPin = 2;                 // (pushbutton)
const int relayPin = 13;                 // (Relay)
int buttonPushCounter = 0;   //counter for the number of button presses
int buttonState = 0;         //current state of the button
int lastButtonState = 0;     //previous state of the button
unsigned long previousMillis = 0;
long OnTime = 10000 ;
long OffTime = 3000;
  Serial.begin(9600);                     //  Serial port, 9600 bps
  pinMode(buttonPin, INPUT);             // buttonPin setup to INPUT
  pinMode(relayPin, OUTPUT);             // relayPin setup to OUTPUT
  for (uint8_t i=0; i < 100; i++) {
    display.setDigits( "----", 4 );
    display.update();
    delay(10);
  sprintf( sbuf, "%04u", buttonPushCounter );
  display.setDigits( sbuf, 4 );
  display.update();
  ts1 = ts2 = ts3 = ts4 = millis();
uint32_t ts;
     ts = millis();
     if ( ts - ts2 >= 5 ) {
     display.update();
     ts2 += 5; // display-update interval = 5msec
  buttonState = digitalRead(buttonPin);
  if (buttonState != lastButtonState) {    // Check the buttonstate (pressed)
  // if pressed then buttonState become to HIGH
        // if the current state is HIGH then the button
      // went from off to on:
      buttonPushCounter++;
      Serial.print("number of button pushesON:  ");
      Serial.println(buttonPushCounter,DEC);
      digitalWrite(relayPin, HIGH);
lastButtonState = buttonState;  // save the current state as the last state, for next time through the loop
You assigned millis() to the variable ts at the start, then continued using millis() throughout the sketch.
Also this part:
if (millis() - buttonStatestartTime >= 1500UL) {
        buttonStatestartTime = buttonStatestartTime + 15000UL;
      if (millis() - buttonStatestartTime >= 1000UL) {
        buttonStatestartTime = buttonStatestartTime + 4000UL;
        digitalWrite(relayPin, LOW);
Firstly you check for 1500, then add 15000 to the variable, same for the if below it, intentional?
Secondly, it doesn't look like it will ever get into that first if(), and that is probably your problem.
