Hi.
I've been trying to solve this one for a few hours now and not gotten anywhere.
A project I'm building needs a counter to be incremented and decremented with two push buttons. The counter has a large range (1-512) so I'd like to avoid having to press the "+" button 255 times to reach the middle. I have already implemented wrap-around at each end of the counter which halves the maximum possible number of button presses.
Ideally, I would have a system where a short press of the "+" or "-" button increments/decrements by 1, and a long press (say, more than 500ms) inc/dec by 10, and continues to do so as long as the button is held.
I already have state change detection working for the single press of each button which inc/dec the counter as it should. I have no idea how to approach the press-and-hold portion of it through.
I have had a look at a few examples of press-and-hold but none seem to quite fit my application and nor have I been successful is altering any to work for me.
Below is the portion of code that I'm currently using. It is working as it should but needs the press-and-hold functionality adding:
const int upButtonPin = 6; //Pin that the Address Up button is connected to. Internal pullup used.
const int downButtonPin = 7; //Pin that the Address Down button is connected to. Internal pullup used.
boolean upButtonState = false; // indicates if the button is active/pressed
boolean upLastButtonState = false; // indicate if the button has been long-pressed
boolean downButtonState = false; // indicates if the button is active/pressed
boolean downLastButtonState = false; // indicate if the button has been long-pressed
void setup();
[Various code etc...]
void loop();
upButtonState = digitalRead(upButtonPin);
if (upButtonState != upLastButtonState) {
if (upButtonState == LOW) {
txAddress ++;
delay(50);
upLastButtonState = upButtonState;
downButtonState = digitalRead(downButtonPin);
if (downButtonState != downLastButtonState) {
if (downButtonState == LOW) {
txAddress --;
delay(50);
downLastButtonState = downButtonState;
if (txAddress > 507) { // Wrap around the TX address if it's higher that 506 (512 minus the 6 faders)
txAddress = 1;
if (txAddress < 1) { // Same but for the bottom end
txAddress = 507;
[Various other code etc...]
