Pressing joystick centers both x and y servo
Hi there.
May I please ask for help - I've messed up couple versions and back to the original.
I have a joystick (+button) controlling 2 servo's.
My joystick's switch pin is connected to digital 2.
I'm trying to get the servo's to center once the joystick button is pressed. Could someone please guide me into getting this to work?
Many many thanks
#include <Servo.h>
Servo myservo1;
Servo myservo2;
int a,b,X,Y;
int YAxis = 1;
int XAxis = 0;
pinMode(XAxis, INPUT);
myservo1.attach(8);
pinMode(YAxis, INPUT);
myservo2.attach(9);
a=myservo1.read();
b=myservo2.read();
X=analogRead(XAxis);
Y=analogRead(YAxis);
if(X>550){
a=a-1;
myservo1.write(a);
delay(50);
if(X<450){
a=a+1;
myservo1.write(a);
delay(50);
if(Y>600){
b=b+1;
myservo2.write(b);
delay(50);
if(Y<450){
b=b-1;
myservo2.write(b);
delay(50);
Welcome to the forum
Today seems to be one of those where new users don't bother to read the advice that they are directed to when joining the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Try adding these lines...
Add this before setup()
int SELECT = 2; // connect SELECT (joystick button) to Digital pin 2
Add this inside setup()
  pinMode(SELECT, INPUT_PULLUP); // configure SELECT button for HIGH when not pressed, LOW when pressed
Add this inside loop()
  if (!digitalRead(SELECT)) { // LOW means button was pressed
    myservo1.write(90); // center myservo1
    myservo2.write(90); // center myservo2
