HI, I'm a first time poster, Ive been playing around with Arduino for some time now learning as i go to write code!
I have written some code to run the elechouse simple Vr board and some other button functions but my issue that I'm having is that once i power up, i have to press reset for the code to run!
i have been playing around adjust code but with no fix, any help would be appreciated as i don't want to have to press reset for the project to run!
Not in the code i have a reset command, this is not to reset the arduino it's to control a power circuit!
Here is my code Thanks Paul
#include <SoftwareSerial.h>
#include "SimpleVR.h"
// Connection
// Arduino VoiceRecognitionModule
// 2 -------> TX
// 3 -------> RX
VR myVR(2, 3); // 2:RX 3:TX, you can choose your favourite pins.
uint8_t buf[65];
int led1 = 12;
int led2 = 11;
int led3 = 10;
int led4 = 9;
int led5 = 4;
int but1 = 7;
int but2 = 8;
int but3 = 5;
int reset = 6;
int state = 0;
int old = 0;
int buttonPoll = 0;
// Variables for millis function
unsigned long lastInputTime = 0;
const unsigned long interval = 120000; // 120000 milliseconds = 2 minutes
0: wait name
1: wait command voice
uint8_t sta;
#define VOICE_PULL (0x2)
// Flag to track button press
bool button3Pressed = false;
void setup(void) {
myVR.begin(9600);
Serial.println(F("Elechouse SimpleVR Module <Control LED> sample."));
if (myVR.checkVersion(buf) > 0) {
Serial.println(F("Found SimpleVR"));
Serial.print(F("SW VER:"));
Serial.print(buf[0], DEC);
Serial.print('.'); Serial.print(buf[1], DEC);
Serial.print('.'); Serial.println(buf[2], DEC);
Serial.print(F("HW VER:"));
Serial.print(buf[3], DEC);
Serial.print('.'); Serial.println(buf[4], DEC);
else {
Serial.println(F("Can't find SimpleVR, please restart Arduino after checking the connection."));
while (1);
if (myVR.setGroup(1) < 0) {
Serial.println(F("Communication error, please restart Arduino after checking the connection."));
while (1);
if (myVR.setEnable(true) < 0) {
while (1);
if (myVR.checkSystemSettings(buf) < 0) {
while (1);
else {
if (buf[0]) {
Serial.println(F("SimpleVR is enabled."));
else {
Serial.println(F("SimpleVR is disabled."));
Serial.print(F("Group "));
Serial.print(buf[1], DEC); Serial.println(F(" is selected."));
if (buf[2] != 0xFF) {
Serial.print(F("Threshold value is ")); Serial.println(buf[2], DEC);
Serial.println("Get Ready To Shot Clays.");
// set led off
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(reset, OUTPUT);
pinMode(but1, INPUT);
pinMode(but2, INPUT);
pinMode(but3, INPUT); // Added pinMode for but3
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
digitalWrite(led5, LOW);
digitalWrite(reset, LOW);
// Wait name is called
void loop(void) {
// Check if but3 is pressed
if (digitalRead(but3) == HIGH && !button3Pressed) {
delay(60); // Debounce
if (digitalRead(but3) == HIGH) { // Check again
state = (state + 1) % 3; // Change state cyclically between 0, 1, and 2
button3Pressed = true;
delay(500); // Wait for button release
if (state == 1) {
digitalWrite(led5, HIGH);
} else if (digitalRead(but3) == LOW && button3Pressed) {
button3Pressed = false; // Reset button press flag when button is released
// Delay Buttons
if (digitalRead(but1) == HIGH) {
delay(2000);
digitalWrite(led3, HIGH);
delay(100);
else {
if (digitalRead(but2) == HIGH) {
delay(2000);
delay(100);
delay(2000);
delay(100);
else {
// millis function to make LED high if no inputs recorded within interval
if (millis() - lastInputTime >= interval) {
digitalWrite(reset, HIGH); // Make LED high
else {
digitalWrite(reset, LOW); // Make LED low
int ret = myVR.recognize(buf, 50);
if (ret > 0) {
uint16_t voice = buf[0];
voice <<= 8;
voice += buf[1];
switch (state) {
case 0:
if (voice == VOICE_PULL) {
if (sta == 0) {
sta = 0;
Serial.println(F("Pull is called. Clay is thrown."));
delay(200);
// Reset lastInputTime when input is detected
lastInputTime = millis();
old = 1;
case 1:
if (sta == 0) {
sta = 0;
delay(200);
delay(2000);
delay(200);
old = state;
// Do nothing here, led5 control is handled above with but3
default:
if (sta == 0) {
sta = 0;
delay(200);
old = 0;
