Sorry. For anyone who's able to help I'll attach the code to this.
#include <SD.h>
#include <SPI.h>
#include <WiFi101.h>
#include <Wire.h>
#include <Adafruit_PN532.h>
#include <Adafruit_MQTT.h>
#include <Adafruit_MQTT_Client.h>
#include <Adafruit_MPR121.h>
#include <Chrono.h>
#include <LightChrono.h>
//WLAN
char ssid[] = "AndroidAP";
char pass[] = "xvpw4672";
int keyIndex = 0;
int status = WL_IDLE_STATUS;
//ADAFRUIT
#define AIO_SERVER "io.adafruit.com"
#define AIO_SERVERPORT 1883
#define AIO_USERNAME -
#define AIO_KEY -
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
#define halt(s) { Serial.println(F( s )); while(1); }
//PN532
#define PN532_SCK (2)
#define PN532_MOSI (3)
#define PN532_SS (4)
#define PN532_MISO (5)
#define PN532_IRQ (2)
#define PN532_RESET (3)
uint8_t success;
uint32_t cardid = 0;
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };
uint8_t uidLength;
Adafruit_PN532 nfc(PN532_IRQ, PN532_RESET);
//MPR121
Adafruit_MPR121 cap = Adafruit_MPR121();
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
unsigned long time;
String left;
String right;
//P.MAP
const int Cols = 16;
const int Rows = 16;
const int Level = 1.2;
int Pin[]= {A15, A14, A13, A12, A11, A10, A9, A8, A7, A6, A5, A4, A3, A2, A1, A0};
int dPin[] = {23, 22, 25, 24, 27, 26, 29, 28, 31, 30, 33, 32, 35, 34, 37, 36};
int i = 0;
int j = 0;
int k = 0;
int n = 0;
int m = 0;
int sensorValue[Cols];
int msensorValue[Cols];
const unsigned char PS_16 = (1 << ADPS2);
const unsigned char PS_32 = (1 << ADPS2) | (1 << ADPS0);
const unsigned char PS_64 = (1 << ADPS2) | (1 << ADPS1);
const unsigned char PS_128 = (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0);
int count = 0;
File pmap;
//OTHER FIELDS
Chrono chrono;
int finalise = 0;
#define LEDPIN 13
void(* resetFunc) (void) = 0;
while (!Serial);
Serial.begin(38400);
//SD CARD
if (!SD.begin(4)) {
Serial.println("SD not found");
while (1);
SD.remove("pmap.txt");
//WINC1500
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WINC1500 not found");
resetFunc();
Serial.println("WINC1500 found");
pinMode(LEDPIN, OUTPUT);
//MPR121
if (!cap.begin(0x5A)){
Serial.println ("MPR121 not found");
while (1);
Serial.println("MPR121 found");
//P.MAP
for (int k = Rows-1; k >= 0 ; k--) {
pinMode(dPin[k], OUTPUT);
for (j = 0; j >= Rows-1 ; j++) {
pinMode (Pin[i], INPUT);
ADCSRA &= ~PS_128;
ADCSRA |= PS_32;
//NFC
nfc.begin();
uint32_t versiondata = nfc.getFirmwareVersion();
if (!versiondata){
Serial.print("PN352 not found");
while (1); //halt
Serial.println("PN532 found"); Serial.println((versiondata>>24) & 0xFF, HEX);
Serial.println("Firmware ver. "); Serial.println((versiondata>>16) & 0xFF, DEC);
nfc.SAMConfig();
Serial.println("Waiting for an ISO14443A Card...");
success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
if (success) {
nfc.PrintHexChar(uid, uidLength);
if (uidLength == 4)
uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);
cardid = uid[0];
cardid <<= 8;
cardid |= uid[1];
cardid <<= 8;
cardid |= uid[2];
cardid <<= 8;
cardid |= uid[3];
Serial.print("Seems to be a Mifare Classic card 11111111111 #");
Serial.println(cardid);
if (success)
Serial.println("Sector 1 (Blocks 4..7) has been authenticated");
uint8_t data[16];
time = millis();
String measurement = "";
currtouched = cap.touched();
pmap = SD.open("pmap.txt", FILE_WRITE);
for (uint8_t i=0; i<12; i++) {
if ((currtouched & _BV(i)) && !(lasttouched & _BV(i))) {
Serial.print(i); Serial.print(" touched at "); Serial.println(time);
if (i == 5){
left = left + " " + time;
else if (i == 9){
right = right + " " + time;
if (!(currtouched & _BV(i)) && (lasttouched & _BV(i))) {
Serial.print(i); Serial.print(" released at "); Serial.println(time);
if (i == 5){
else if (i == 9){
for (int i = Rows-1; i >= 0 ; i--) {
digitalWrite (dPin[i], HIGH);
for (int m = Cols-1; m >= 0 ; m--) {
sensorValue[m] = analogRead (Pin[m]) * Level;
if (sensorValue[m] < 50) {
sensorValue[m] = 0;
msensorValue[m] = map (sensorValue[m], 0, 1024, 255, 0);
measurement = measurement + "a" + sensorValue[m];
digitalWrite (dPin[i], LOW);
Serial.println(measurement);
if(pmap){
pmap.println(measurement);
count++;
lasttouched = currtouched;
pmap.close();
if(time > 10000 && finalise == 0){
finalise++;
Serial.println(left);
Serial.println(right);
MQTT_connect();
MQTT_publishMethod(left, ".bench-left");
MQTT_publishMethod(right, ".bench-right");
pmap = SD.open("pmap.txt", FILE_READ);
char character;
String mapRead = "";
int q = 0;
if (pmap) {
while (((character = pmap.read()) != -1)) {
mapRead = mapRead + character;
q++;
if(q >= 100){
MQTT_publishMethod(mapRead, ".bench-seat");
delay(5000);
q = 0;
mapRead = "";
Serial.println("Could not read.");
resetFunc();
void MQTT_connect() {
int8_t ret;
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
uint8_t timeout = 10;
while (timeout && (WiFi.status() != WL_CONNECTED)) {
timeout--;
if (mqtt.connected()) {
return;
Serial.print("Connecting to MQTT... ");
while ((ret = mqtt.connect()) != 0) {
Serial.println(mqtt.connectErrorString(ret));
Serial.println("Retrying MQTT connection in 5 seconds...");
mqtt.disconnect();
delay(5000);
Serial.println("MQTT Connected!");
void MQTT_publishMethod(String input, String feed){
String baseUrl = "baynesstua/feeds/";
String feedUrl = baseUrl + "id" + cardid + feed;
const char* lenChar = feedUrl.c_str();
int len = strlen(lenChar);
len++;
char urlChar[len];
feedUrl.toCharArray(urlChar, len);
Adafruit_MQTT_Publish obj = Adafruit_MQTT_Publish(&mqtt, urlChar);
int dataLen = input.length() + 1;
char dataChar [dataLen];
input.toCharArray(dataChar, dataLen);
obj.publish(dataChar);
Arduino_Main_230418_Rebuild.ino (7.77 KB)
