Pressure mat
Hey guys,
I am completely new to arduino and I am trying to make a sensor-mat (force sensors). I want to calibrate all four sensors so that they start at 0, this way the difference in weight placement can be measured afterwards.
Pressure.ino (2.54 KB)
//#define DEBUG
// Include Libraries
#include "Settings.h"
int sensorPins[numberOfInputs] = { A0 , A1 , A2 , A3};
int sensorMax[numberOfInputs] = { A0 , A1 , A2 , A3};
int sensorMin[numberOfInputs] = { A0 , A1 , A2 , A3};
int valueReadings[numberOfInputs];
int ledPin   = 13;
int count = 0;
// Variables
int sensorValue = 0;         // the sensor value
//int sensorMin = 50;        // minimum sensor value
//int sensorMax = 0;           // maximum sensor value
    Serial.begin(9600);  // Baud Rate Serial Communication
pinMode(ledPin, OUTPUT); // LED
  // Define Sensorpins as inputs
  for(int i = 0; i < numberOfInputs; i++)
{  pinMode(sensorPins[i], INPUT);
 digitalWrite(13, HIGH);
  // calibrate during the first five seconds using all sensor pins, so each sensor  has to see the max and min pressure during that time !!!
  while (millis() < 5000) {
    for (int I = 0 ; I < numberOfInputs; I++)
      sensorValue = analogRead(sensorPins[i]);
      // record the maximum sensor value
      sensorMax[I] = max(sensorMax[I], sensorValue);
      // record the minimum sensor value
      sensorMin[I] = min(sensorMin[I], sensorValue);
  // after this sensorMin hold the minimum value recorded in the first 5 seconds and sensorMax the highest one
 digitalWrite(13, LOW);
for (int i=0; i<numberOfInputs; i++) valueReadings[i] = map(analogRead(sensorPins[i]), sensorMin[I], sensorMax[I], 0, 100);
 valueReadings[0] = map(analogRead(sensorPins[0]), 0, 1023, 0, 100);
 valueReadings[1] = map(analogRead(sensorPins[1]), 0, 1023, 0, 100);
 valueReadings[2] = map(analogRead(sensorPins[2]), 0, 1023, 0, 100);
 valueReadings[3] = map(analogRead(sensorPins[3]), 0, 1023, 0, 100);
int PercentageL1 = valueReadings[1];
int PercentageL2 = valueReadings[0];
int PercentageR1 = valueReadings[2];
int PercentageR2 = valueReadings[3];
Serial.print("Time: ");
 Serial.print(count);
    Serial.println(" seconds");
  Serial.println("L1: " + String(PercentageL1) + " %" "  R1: " + String(PercentageR1) + " %");
  Serial.println("L2: " + String(PercentageL2) + " %" "  R2: " + String(PercentageR2) + " %");
 count += 1;
Strange values to use for initial min and max. Perhaps you meant:
int sensorMax[numberOfInputs] = { 0 , 0 , 0 , 0};
int sensorMin[numberOfInputs] = { 1023, 1023, 1023, 1023};
Here, I’ve cleaned up the code for you:
//#define DEBUG
// #include "Settings.h"
const byte numberOfInputs = 4;
//                                 L1, L2, R1, R2
int sensorPins[numberOfInputs] = { A1 , A0 , A2 , A3};
int sensorMax[numberOfInputs] = { 0, 0, 0, 0};
int ledPin   = 13;
// Variables
  // Define Sensor pins as inputs (NOT NEEDED FOR ANALOG INPUTS)
  // for (int i = 0; i < numberOfInputs; i++)
  //  pinMode(sensorPins[i], INPUT);
  digitalWrite(ledPin, HIGH);
  // so each sensor has to see the max and min pressure during that time !!!
      sensorValue = analogRead(sensorPins[I]);
  // Now sensorMin[] hold the minimum value recorded in the first 5 seconds and
  // sensorMax[] the highest one
  digitalWrite(ledPin, LOW);
    // Note: If the input to map() goes outside the limits, the output will, too.
    // If that is possible, use constrain() on the input or output to avoid problems.
    valueReadings[i] = constrain(analogRead(sensorPins[i]),  sensorMin[i], sensorMax[i]);
  // valueReadings[0] = map(analogRead(sensorPins[0]), 0, 1023, 0, 100);
  // valueReadings[1] = map(analogRead(sensorPins[1]), 0, 1023, 0, 100);
  // valueReadings[2] = map(analogRead(sensorPins[2]), 0, 1023, 0, 100);
  // valueReadings[3] = map(analogRead(sensorPins[3]), 0, 1023, 0, 100);
  int PercentageL1 = map(valueReadings[0], sensorMin[0], sensorMax[0], 0, 100);
  int PercentageL2 = map(valueReadings[1], sensorMin[1], sensorMax[1], 0, 100);
  int PercentageR1 = map(valueReadings[2], sensorMin[2], sensorMax[2], 0, 100);
  int PercentageR2 = map(valueReadings[3], sensorMin[3], sensorMax[3], 0, 100);
  Serial.print(millis() / 1000.0, 3);
