Pressure measurement with multiple sensors (Omron D6FPH)
Hi @ruilviana,
for now this has helped me a lot. I just ordered this Multiplexer and a second Sensor just to test, if it will work.
The problem I have is that I need to "simultaneously" measure the pressures with the different sensors. This means that I have to program in such a way that the sensors can measure directly one after the other, i.e. the multiplexer releases the individual channels one after the other.
Since the sensors are all the same and therefore run under the same code, the code for the individual sensors then remains the same and I must program that the individual channels are released one after the other by the multiplexer? Or does that not work like that?
